주요 콘텐츠로 건너뛰기
HP Pavilion 14-cf0014dx Battery Replacement
필요한 것
  1. HP Pavilion 14-cf0014dx Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Flip the device over so that the backside is facing you.
    • Remove the rubber feet to expose six screws.
    • Using the Phillips #1 screwdriver, remove six screws securing the back panel to the device.
  2. HP Pavilion 14-cf0014dx Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic opening tool and run it along the edges of the laptop.
    • Remove the back panel from the device.
  3. HP Pavilion 14-cf0014dx Battery Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Using the Phillips #0 screwdriver, remove the four screws securing the battery in place.
  4. HP Pavilion 14-cf0014dx Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Lift the battery up and out and remove it from the device.
결론
For optimal performance, after completing this guide, calibrate your newly installed battery.
작성자
2다른 기여자 명과 함께
Sam Cole
회원 가입일: 10/25/21
813 평판
안내서 7개를 작성함
UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 UMass Dartmouth, Team 2-7, Sinclaire Fall 2021 회원
UMASSD-SINCLAIRE-F21S2G7
3 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 1,804
