주요 콘텐츠로 건너뛰기
HP Pavilion 15-au123cl RAM Replacement
필요한 것
  1. HP Pavilion 15-au123cl RAM Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Make sure the laptop is off and unplugged before starting.
    • Using the plastic opening tool, remove the top rubber feet on the back panel as it hides one of the screws we will be removing.
  2. HP Pavilion 15-au123cl RAM Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Using a PH0 screwdriver, unscrew the ten 4.4mm Phillips head screws located on the back panel.
    Correction. Top two screen pivot screws are bigger than the 8, 4mm.
    Mitchell Culp II - 답글
  3. HP Pavilion 15-au123cl RAM Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Using the plastic opening tool, remove the back cover of the laptop.
    • It is recommended that you start with a corner and run the tool throughout the edges of the cover.
    • Be sure not to bend the cover by applying too much force.
    What? I think you have have neglected to mention the DVD drawer. I believe it needs to be pulled out after removing the center screw and before removing the cover.
    Dan Enslow - 답글
    Yes, best to remove the drawer as recommended. Also there are 3 screws holding the battery, not 2.
    Lastly, pay careful attention to the orientation photo when removing the back.
    I did not have the plastic tool but used a small Teflon type kitchen spatula and it did the trick. Do not use a metal screw driver or other such tool.
    Edward Yandek - 답글
  4. HP Pavilion 15-au123cl RAM Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Using a PH0 screwdriver, unscrew the two 3.8mm PH0 Phillips head screws that hold the battery in place.
    there is a third screw on bottom left of battery (in picture above)
    Paul Behrman - 답글
  5. HP Pavilion 15-au123cl RAM Replacement: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-au123cl RAM Replacement: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-au123cl RAM Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully disconnect the cable connecting the top of the battery and remove the battery.
  6. HP Pavilion 15-au123cl RAM Replacement, RAM: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-au123cl RAM Replacement, RAM: 6 단계, 이미지 2개 중 2개
    • The RAM is located at the lower middle region of the motherboard.
    • Push down on the clips on both sides of the RAM stick evenly.
    • The RAM will become loose and move upward when the clips are pushed.
  7. HP Pavilion 15-au123cl RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Pull the RAM stick out of the motherboard.
    • The same steps work on both sticks of RAM.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Mohammad Gardezi
회원 가입일: 10/17/17
1,420 평판
안내서 6개를 작성함
USF Tampa, Team S13-G3, Cagle Fall 2017 USF Tampa, Team S13-G3, Cagle Fall 2017 회원
USFT-CAGLE-F17S13G3
2 회원들
안내서 6개를 작성함
댓글 한 개
Thanks mate….your steps are helpful <3
Can you please guide on how to buy the RAM for this laptop…my current RAM is 4GB
Im planning to upgrade to 8GB
thanks
Gokul Prasad Rao - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 25
전체 시간: 1,379
