주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Thermal Paste Replacement
필요한 것
  1. HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 1 단계, 이미지 1/2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 1 단계, 이미지 2/2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Thermal Paste Replacement, Disc Drive: 2 단계, 이미지 1/1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Thermal Paste Replacement: 3 단계, 이미지 1/2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 3 단계, 이미지 2/2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Thermal Paste Replacement: 4 단계, 이미지 1/2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 4 단계, 이미지 2/2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 5 단계, 이미지 1/3 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 5 단계, 이미지 2/3 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 5 단계, 이미지 3/3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 6 단계, 이미지 1/2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 6 단계, 이미지 2/2
    • Remove four 3mm Phillips #00 screws holding the CPU heatsink in place.
  7. HP Pavilion 15-ba003ds Thermal Paste Replacement: 7 단계, 이미지 1/3 HP Pavilion 15-ba003ds Thermal Paste Replacement: 7 단계, 이미지 2/3 HP Pavilion 15-ba003ds Thermal Paste Replacement: 7 단계, 이미지 3/3
    • Gently wiggle and remove CPU heatsink.
    • Do not attempt to pull the heatsink away without having wiggled it, as it may cause damage to your motherboard.
    • Wiggle while holding the heatink on top of the CPU, not the fan housing.
  8. HP Pavilion 15-ba003ds Thermal Paste Replacement: 8 단계, 이미지 1/2 HP Pavilion 15-ba003ds Thermal Paste Replacement: 8 단계, 이미지 2/2
    • Generously apply the 99% isopropyl alcohol to your microfiber cloth.
    • Make sure that the thermal paste is completely wiped away and that the processor is dry
    • Apply a small pea sized amount of thermal paste to the processor.
    • Ensure that when you’re wiping away the old thermal paste that none of it falls onto the motherboard beneath it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Joseph Chia
회원 가입일: 01/14/20
355 평판
안내서 3개 작성하였습니다
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 51
전체 시간: 2,319
