주요 콘텐츠로 건너뛰기
HP Pavilion 15-ba003ds Thermal Paste Replacement
필요한 것
  1. HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Thermal Paste Replacement, Disc Drive: 2 단계, 이미지 1개 중 1개
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Thermal Paste Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement: 3 단계, 이미지 2개 중 2개
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Thermal Paste Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement: 4 단계, 이미지 2개 중 2개
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
  5. HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 5 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 5 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: 5 단계, 이미지 3개 중 3개
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: 6 단계, 이미지 2개 중 2개
    • Remove four 3mm Phillips #00 screws holding the CPU heatsink in place.
  7. HP Pavilion 15-ba003ds Thermal Paste Replacement: 7 단계, 이미지 3개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement: 7 단계, 이미지 3개 중 2개 HP Pavilion 15-ba003ds Thermal Paste Replacement: 7 단계, 이미지 3개 중 3개
    • Gently wiggle and remove CPU heatsink.
    • Do not attempt to pull the heatsink away without having wiggled it, as it may cause damage to your motherboard.
    • Wiggle while holding the heatink on top of the CPU, not the fan housing.
  8. HP Pavilion 15-ba003ds Thermal Paste Replacement: 8 단계, 이미지 2개 중 1개 HP Pavilion 15-ba003ds Thermal Paste Replacement: 8 단계, 이미지 2개 중 2개
    • Generously apply the 99% isopropyl alcohol to your microfiber cloth.
    • Make sure that the thermal paste is completely wiped away and that the processor is dry
    • Apply a small pea sized amount of thermal paste to the processor.
    • Ensure that when you’re wiping away the old thermal paste that none of it falls onto the motherboard beneath it.
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Joseph Chia
회원 가입일: 01/14/20
355 평판
안내서 3개를 작성함
York University, Team S1-G9, Woodhouse Winter 2020 York University, Team S1-G9, Woodhouse Winter 2020 회원
YORK-WOODHOUSE-W20S1G9
3 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 12
지난 30일: 69
전체 시간: 2,628
