주요 콘텐츠로 건너뛰기
HP Pavilion 15-cd040wm CD Drive Replacement
필요한 것
  1. HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm CD Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2개 중 2개
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm CD Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm CD Drive Replacement: 2 단계, 이미지 2개 중 2개
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm CD Drive Replacement: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-cd040wm CD Drive Replacement: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-cd040wm CD Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm CD Drive Replacement, Battery: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm CD Drive Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm CD Drive Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm CD Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: 6 단계, 이미지 2개 중 1개 HP Pavilion 15-cd040wm CD Drive Replacement, CD Drive: 6 단계, 이미지 2개 중 2개
    • Slide the CD drive out the side of the laptop.
결론
작성자
2다른 기여자 명과 함께
Brian Cornet
회원 가입일: 10/21/19
316 평판
안내서 3개를 작성함
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G1
4 회원들
안내서 8개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 15
지난 30일: 22
전체 시간: 560
