주요 콘텐츠로 건너뛰기
HP Pavilion 15-cd040wm Hard Drive Replacement
필요한 것
  1. HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 1/2 HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: 1 단계, 이미지 2/2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Hard Drive Replacement: 2 단계, 이미지 1/2 HP Pavilion 15-cd040wm Hard Drive Replacement: 2 단계, 이미지 2/2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Hard Drive Replacement: 3 단계, 이미지 1/3 HP Pavilion 15-cd040wm Hard Drive Replacement: 3 단계, 이미지 2/3 HP Pavilion 15-cd040wm Hard Drive Replacement: 3 단계, 이미지 3/3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: 4 단계, 이미지 1/2 HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: 4 단계, 이미지 2/2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Hard Drive Replacement: 5 단계, 이미지 1/2 HP Pavilion 15-cd040wm Hard Drive Replacement: 5 단계, 이미지 2/2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: 6 단계, 이미지 1/2 HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: 6 단계, 이미지 2/2
    • Using a spudger or the opening tool, lift the end closest to the battery until you can hold the hard drive with your hands.
  7. HP Pavilion 15-cd040wm Hard Drive Replacement: 7 단계, 이미지 1/2 HP Pavilion 15-cd040wm Hard Drive Replacement: 7 단계, 이미지 2/2
    • Carefully remove the connector ribbon cable from the elevated end of the hard drive, then remove the hard drive.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Brian Cornet
회원 가입일: 10/21/19
316 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 UMass Dartmouth, Team S1-G1, Botvin Fall 2019 회원
UMASSD-BOTVIN-F19S1G1
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 1,873
