주요 콘텐츠로 건너뛰기
HP Pavilion 15-cs3xxx Battery Replacement
필요한 것
  1. HP Pavilion 15-cs3xxx Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-cs3xxx Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Power off and unplug the laptop from any power source.
    • Flip the laptop over so the bottom is facing up.
    • Prior to removing the two screws near the hinge, remove the two rubber feet with a spudger or opening tool.
    • Two of the five screws are under the rubber feet nearest the hinges.
    • Use a Phillips screwdriver to remove the five screws on the underside of the laptop.
  2. HP Pavilion 15-cs3xxx Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-cs3xxx Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use an opening tool and picks to carefully pry off the back cover.
    • Work your way around the perimeter and release the clips holding the case to the device.
    • Carefully remove the back case.
  3. HP Pavilion 15-cs3xxx Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the battery which should be a large rectangular component located at the corner of the laptop.
    • Use a screwdriver to remove the four screws holding the battery in place.
  4. HP Pavilion 15-cs3xxx Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Carefully remove the battery from the chassis.
    • Install the new battery and repeat the process to secure it.
결론
Following these steps in reverse order to reassemble your device
다른 4명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Victoria Dobbs
회원 가입일: 05/28/23
191 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 46
지난 30일: 166
전체 시간: 3,198
