주요 콘텐츠로 건너뛰기
HP Pavilion 15-e043cl Optical Drive Replacement
필요한 것
  1. HP Pavilion 15-e043cl Optical Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion 15-e043cl Optical Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
  2. HP Pavilion 15-e043cl Optical Drive Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion 15-e043cl Optical Drive Replacement: 2 단계, 이미지 2개 중 2개
    • Lift the battery up and out of the device by the inward-facing edge.
  3. HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: 3 단계, 이미지 3개 중 1개 HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: 3 단계, 이미지 3개 중 2개 HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: 3 단계, 이미지 3개 중 3개
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
  4. HP Pavilion 15-e043cl Optical Drive Replacement, Optical Drive: 4 단계, 이미지 2개 중 1개 HP Pavilion 15-e043cl Optical Drive Replacement, Optical Drive: 4 단계, 이미지 2개 중 2개
    • Remove the black screw nearby to the disk tray.
    • Push the disk tray out of the laptop near the stamp that says "RELEASE."
결론
작성자
3다른 기여자 명과 함께
Cace Letendre
회원 가입일: 10/25/22
528 평판
안내서 6개를 작성함
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 회원
UMASSD-SINCLAIRE-F22S4G5
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 257
