소개
WARNING: The computer should be off (no power running), unplugged and the battery must be removed to prevent electrical shock.
If your speakers no longer work, are static, or lack continuity in sound use this guide to replace the speakers in the HP Pavilion 15-n210dx. Some prerequisites are needed.
The speakers emit sound through connection of wires connected to routing channel. If the wires and/or the speakers are damaged, they must be replaced.
Please follow the speaker section of the troubleshooting page to see if any of the suggested solutions solve the problem(s) before attempting to replace the speakers.
A spudger and a Y0 screw driver should be at hand before starting this replacement.
필요한 것
Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
