주요 콘텐츠로 건너뛰기
HP Pavilion 17-e146us Charger Port Replacement
필요한 것
  1. HP Pavilion 17-e146us Charger Port Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the device over.
  2. HP Pavilion 17-e146us Charger Port Replacement: 2 단계, 이미지 1/2 HP Pavilion 17-e146us Charger Port Replacement: 2 단계, 이미지 2/2
    • Move the battery lock switch to the right to unlock. The battery release button will unlock the battery from the computer.
    • The battery release button is located above the the battery.
  3. HP Pavilion 17-e146us Charger Port Replacement: 3 단계, 이미지 1/1
    • The battery will unlock from the computer.
    • Remove the unlocked battery from the computer.
  4. HP Pavilion 17-e146us Charger Port Replacement, Keyboard: 4 단계, 이미지 1/3 HP Pavilion 17-e146us Charger Port Replacement, Keyboard: 4 단계, 이미지 2/3 HP Pavilion 17-e146us Charger Port Replacement, Keyboard: 4 단계, 이미지 3/3
    • Remove the 6.25 mm screw in the left-lower hand corner of the battery port using a Phillips head screw driver.
  5. HP Pavilion 17-e146us Charger Port Replacement: 5 단계, 이미지 1/1
    • Remove the HP protect smart ventilation case.
    • The smart ventilation is a part of the back cover of the device
  6. HP Pavilion 17-e146us Charger Port Replacement: 6 단계, 이미지 1/1
    • Remove seven 6.5 mm screws using a Phillips #0 screwdriver.
    • Remove four 3.0 mm screws located in the charger port using a Phillips #0 screwdriver.
  7. HP Pavilion 17-e146us Charger Port Replacement: 7 단계, 이미지 1/2 HP Pavilion 17-e146us Charger Port Replacement: 7 단계, 이미지 2/2
    • Pull and remove the disk drive.
    • The disk drive is located on the left side of the device when it is turned over.
    • Remove two 3.00 mm screws on the inside of the disk drive using a Phillips screwdriver.
  8. HP Pavilion 17-e146us Charger Port Replacement: 8 단계, 이미지 1/1
    • Apply firm pressure inside the release port using a narrow tool such as a screw driver or tweezers.
    • The release port releases the keyboard.
  9. HP Pavilion 17-e146us Charger Port Replacement: 9 단계, 이미지 1/1
    • Flip device over so that the cover is facing towards you
  10. HP Pavilion 17-e146us Charger Port Replacement: 10 단계, 이미지 1/3 HP Pavilion 17-e146us Charger Port Replacement: 10 단계, 이미지 2/3 HP Pavilion 17-e146us Charger Port Replacement: 10 단계, 이미지 3/3
    • Open device. The keyboard should be separate from the inside panel.
    • If the keyboard does not automatically pop out, use a spudger or opening tool along the edge of the front panel and the keyboard to pop the keyboard out.
    • Detach the keyboard's cable connector from the motherboard.
  11. HP Pavilion 17-e146us Charger Port Replacement, Motherboard: 11 단계, 이미지 1/1
    • Remove three 6.5 mm Phillips screws located underneath the keyboard using a Phillips #0 screwdriver.
  12. HP Pavilion 17-e146us Charger Port Replacement: 12 단계, 이미지 1/1
    • Place wedge tool in-between the front panel and the cover underneath the keyboard
    • Use wedge tool to pop the two covers apart.
    • This may require some force.
  13. HP Pavilion 17-e146us Charger Port Replacement: 13 단계, 이미지 1/2 HP Pavilion 17-e146us Charger Port Replacement: 13 단계, 이미지 2/2
    • Remove the motherboard using your hands
    • The motherboard is large green portion located inside the device
  14. HP Pavilion 17-e146us Charger Port Replacement, Charger Port: 14 단계, 이미지 1/2 HP Pavilion 17-e146us Charger Port Replacement, Charger Port: 14 단계, 이미지 2/2
    • The charging port is attached to the motherboard and is on the right side of the device if it is facing you.
    • Remove the charging port from motherboard by hand.
    • Be careful not to break the motherboard during removal
결론
Emma Neumann
회원 가입일: 09/04/19
629 평판
안내서 5개 작성하였습니다
University of Alabama, Team S2-G7, Bedsole Fall 2019 University of Alabama, Team S2-G7, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S2G7
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 16
전체 시간: 853
