소개
The front panel is removed to access the inner components and is a precursor to RAM, hard drive, keyboard, and screen repair. It is difficult to do because the front panel is very firmly secured and will require a lot of time, strength, and patience to remove.
필요한 것
Remove the following six screws with a Phillips #1 screwdriver:
Two 7 mm screws.
Two 7 mm screws.
Two 4.8 mm screws.
At step 11 there are only two screws. Those marked in yellow in the picture.
Paul Clark - 답글
Step 10, the screws under the end caps. My device also only had the yellow screws in place.
다른 한 분이 해당 안내서를 완성하였습니다.
