주요 콘텐츠로 건너뛰기
HP Pavilion Sleekbook 15-b142dx Keyboard Replacement
필요한 것
  1. HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Removing Keyboard: 1 단계, 이미지 1/3 HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Removing Keyboard: 1 단계, 이미지 2/3 HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Removing Keyboard: 1 단계, 이미지 3/3
    • Open the laptop and locate the keyboard. Identify the borders of the keyboard.
    • Taking plastic opening tools in hand, carefully and gently pry open the outer perimeter of the keyboard.
    Wrong, you can't just remove the keyboard, you have to remove the 2 bolts labeled keyboard on the bottom or you are going to have a bad time.
    dloeper2391 - 답글
    Yes, as dloeper noted, the two screws on the bottom with the keyboard icons must be removed prior to this step. Might as well remove all the screws from the bottom, they all need to be removed (10 total, all the same size).
    maccentric - 답글
  2. HP Pavilion Sleekbook 15-b142dx Keyboard Replacement, Replacing Keyboard: 2 단계, 이미지 1/1
    • Once part of the keyboard has popped up, continue to lift the keyboard until it is removed.
    Need to detach the two ribbon cables.
    Mat Kramer - 답글
    how do you reattach the ribbon cables?
    bhdxxx1984 - 답글
    I only had to remove 1 cable for the keyboard, the wide one. It is removed, and reattached, by flipping up the brown part of the socket. It was a little stiff on mine; I used 2 fingernails on either end of the socket to raise the flap up.
    maccentric -
결론
다른 8명이 해당 안내서를 완성하였습니다.
Jonathan
회원 가입일: 01/13/15
755 평판
안내서 3개 작성하였습니다
USF Tampa, Team 3-3, Hickman Winter 2015 USF Tampa, Team 3-3, Hickman Winter 2015 회원
USFT-HICKMAN-W15S3G3
4 회원들
안내서 5개 작성하였습니다
댓글 2개
And how I remove the bezel?
Lorenzo Ricci - 답글
Where do I get the replacement keyboard for this?
I have an HP Pavilion Sleekbook 15-b012ee and I feel that the same keyboard would work
Author, please share the link
Tommy Vercaty - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 3,220
