주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Pavilion dv6000 Optical Drive Replacement
필요한 것
  1. HP Pavilion dv6000 Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1개 중 1개
    • Before proceeding, it is recommended to remove the battery to prevent any electrical damage to components.
    • Remove the single 5.6 mm Phillips screw securing the optical drive to the lower case.
  2. HP Pavilion dv6000 Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Insert the tip of an unrolled paper clip into the small hole located on the side of the optical drive.
    • The tray will partially pop out of the laptop.
    • Firmly pull the drive straight away from the laptop.
    • While pulling the drive out, be careful not to bend the sliding rails on both sides of the optical drive.
    • At this point you can remove the entire optical drive, or you can continue to disassemble the optical drive assembly.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Walter Galan
709,695 평판
안내서 1,203개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 23
지난 30일: 80
전체 시간: 8,576
