주요 콘텐츠로 건너뛰기
HP Pavilion dv7-6c90us Cooling Fan Replacement
필요한 것
  1. HP Pavilion dv7-6c90us Cooling Fan Replacement, Cooling fan: 1 단계, 이미지 1개 중 1개
    • Place the laptop on a large flat surface, and turn it over.
  2. HP Pavilion dv7-6c90us Cooling Fan Replacement: 2 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 2 단계, 이미지 2개 중 2개
    • The latch pictured on the bottom of the laptop holds the battery in place. Slide the latch to the left to remove the battery.
    • Slide the latch to the right to release the t-shaped plastic cover.
    • Lift the cover up and gently remove it.
  3. HP Pavilion dv7-6c90us Cooling Fan Replacement: 3 단계, 이미지 1개 중 1개
    • Sketch a diagram of the bottom of the laptop. Make sure to mark all of the screw holes.
    • Note: This step is optional, but it is highly recommended. The diagram is used exclusively for keeping track of the screws on the bottom of the laptop.
    • Note: The three screws in the blue box are under the hard drive and are not immediately visible. The three screws in the red box are under the CD drive and are also not visible at this point in disassembly.
    I additionally tape the screws to the spot on the diagram. Not even one dropped or missing or misplaced screw!
    peggy - 답글
  4. HP Pavilion dv7-6c90us Cooling Fan Replacement: 4 단계, 이미지 3개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 4 단계, 이미지 3개 중 2개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 4 단계, 이미지 3개 중 3개
    • Carefully remove all twenty screws from the external laptop case.
    • Remove the eight Phillips PM2.5x5.0 screws from both hard drive compartments, and place them on the diagram.
    • Note:If a screw is too tight, use pliers for additional grip and torque.
    • Carefully place all screws in the correct spot on the diagram. Many screws are different sizes and lengths. It is extremely important that all screws go back into the same screw hole they came out of during re-assembly.
    • The screw sizes and types are: Phillips PM2.0x4.0, PM2.5x5.0, PM3.0x4.0, PM 2.5x7.0, PM 2.5x3.0, PM 2.5x9.0, PM 2.0x2.0, and PM 2.0x7.0.
  5. HP Pavilion dv7-6c90us Cooling Fan Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 5 단계, 이미지 2개 중 2개
    • Disconnect the hard drive by gently pulling the plastic tab connector from the motherboard port.
    • Remove the empty hard drive bracket and hard drive. Set them aside until re-assembly.
    When removing the hard drive cable. There’s 2 other cables in the vicinity that needs to be removed as well or you will hit a snag later.
    deeene - 답글
  6. HP Pavilion dv7-6c90us Cooling Fan Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the screws from the hard drive compartments and place them in the matching places on the diagram.
  7. HP Pavilion dv7-6c90us Cooling Fan Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 7 단계, 이미지 2개 중 2개
    • Gently push the tabs away from the sides of the RAM chips to release them. (Push the tabs in the direction of the arrows.)
    • Remove both RAM chips by gently pulling them out at a 45 degree angle.
  8. HP Pavilion dv7-6c90us Cooling Fan Replacement: 8 단계, 이미지 3개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 8 단계, 이미지 3개 중 2개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 8 단계, 이미지 3개 중 3개
    • To begin removing the wireless card, disconnect the attached wires.
    • Remove the two PM 2.0x4.0 screws from the corners of the wireless card. Removing the screws will cause the wireless card to pop up.
    • Carefully remove the wireless card.
    • Note: Make a note of the color of the wire attached to each node. The connection nodes are marked with yellow circles.
  9. HP Pavilion dv7-6c90us Cooling Fan Replacement: 9 단계, 이미지 1개 중 1개
    • Place your fingernails in-between the crevice of the CD drive and the main body of the laptop. Carefully pull the drive out of the slot.
  10. HP Pavilion dv7-6c90us Cooling Fan Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the three screws on the seam of the CD disk drive slot.
  11. HP Pavilion dv7-6c90us Cooling Fan Replacement: 11 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 11 단계, 이미지 2개 중 2개
    • Turn the laptop right-side-up, and open the screen. Loosen the keyboard by carefully prying it up using your fingernails, carefully working along the edges.
    • Note: Keyboard keys may pop off. Re-attach them after you re-attach the keyboard.
    • Slowly lift the keyboard away from the case.
    • Lift the plastic tab that connects the keyboard ribbon cable to the motherboard.
    • Set the keyboard aside.
  12. HP Pavilion dv7-6c90us Cooling Fan Replacement: 12 단계, 이미지 1개 중 1개
    • Carefully lift the four plastic tabs under the keyboard, and gently disconnect the ribbons under each one.
  13. HP Pavilion dv7-6c90us Cooling Fan Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the two PM 2.5x5.0 screws from beneath the keyboard.
    • Note: Both screws under the keyboard are the same size, so they can go to either location in re-assembly.
  14. HP Pavilion dv7-6c90us Cooling Fan Replacement: 14 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 14 단계, 이미지 2개 중 2개
    • Use your fingers to release the top cover. Start at the top right corner. and work your way around the faceplate.
    • Note: You can also use a small flat-head screwdriver if your fingers do not fit. You will hear some popping sounds as the faceplate comes off.
    • WARNING: There are several sharp edges that may cut fingers. Do not force the top faceplate off. If it does not release with slight pressure, make sure all screws are removed from the back of the laptop case.
  15. HP Pavilion dv7-6c90us Cooling Fan Replacement: 15 단계, 이미지 1개 중 1개
    • The laptop should now look like this.
    There is a horizontal grey wire in the middle of the picture. There is no additional showing where is goes on the left.
    I was careless when I completed step 15 documentation. Now when I am in the process of reversing the process, I don’t know where to connector.
    Need a 19.5 step showing what is happening in this area of the laptop.
    Ron Hall - 답글
  16. HP Pavilion dv7-6c90us Cooling Fan Replacement: 16 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 16 단계, 이미지 2개 중 2개
    • Lift the tab covering the SD card reader ribbon to unplug it.
    • Gently pull the SD card reader wires to disconnect them from the motherboard.
  17. HP Pavilion dv7-6c90us Cooling Fan Replacement: 17 단계, 이미지 3개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 17 단계, 이미지 3개 중 2개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 17 단계, 이미지 3개 중 3개
    • Unplug the speaker wire from the port in the lower left hand corner of the laptop.
    • Gently pull the plastic tab attached to the display wire to disconnect the display.
    • Disconnect the fan power supply cable.
  18. HP Pavilion dv7-6c90us Cooling Fan Replacement: 18 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 18 단계, 이미지 2개 중 2개
    • Remove the power supply cord from the port on the right hand side of the motherboard (marked with red box).
  19. HP Pavilion dv7-6c90us Cooling Fan Replacement: 19 단계, 이미지 3개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 19 단계, 이미지 3개 중 2개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 19 단계, 이미지 3개 중 3개
    • Remove the five screws that hold the motherboard and fan in place.
    • Carefully remove the motherboard and fan.
    • CAUTION: Be careful not to bend or break the motherboard body or USB ports.
    Thanks for this helpful guide! But 2 edits were necessary, one in this step to avoid breaking something.
    Other than that everything went well. So thanks again!
    Zen Balancer - 답글
    My raw edit:
    "WARNING: motherboard can't be removed without removing the 2 screws holding the fan to the laptop body! That edit for their position (not clear in this shot) was declined. I would have broken something if I kept on pulling with those screws too in place."
    I added a new picture showing clearly at least one of the two screws, but positioned the marker also on the other less visible one.
    Zen Balancer - 답글
    At this point I still had two wire harness connections to the underside of the motherboard that were preventing it from lifting out.
    Jeff Slutz - 답글
    The two screws by the fan are indicated on the second photo, but perhaps would be better to also indicate them on the first photo. In addition, similar to the other comment, I also had two wire connections that were still connected that prevented the motherboard from lifting out, but they were easy to see and easy to disconnect, but this should be added to the instructions.
    AndrewE - 답글
    En este punto no es posible sacar la placa. Faltan retirar dos tornillos del fan, el conector del CDROM y descalzar/levantar el parlante superior.
    Nicolás López - 답글
  20. HP Pavilion dv7-6c90us Cooling Fan Replacement: 20 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 20 단계, 이미지 2개 중 2개
    • Flip the motherboard over. Use a micro- screwdriver to remove the screws holding the fan assembly in place.
    • Note: You may need to cut or remove a bar code sticker from the fan/heat sink assembly.
    • Remove screws from the heat sink assembly using a #1 Phillips screwdriver.
  21. HP Pavilion dv7-6c90us Cooling Fan Replacement: 21 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 21 단계, 이미지 2개 중 2개
    • Remove the fan/heat sink assembly.
    • Note: The assembly may stick, due to the connection made with the heat sinks through the thermal compound.
  22. HP Pavilion dv7-6c90us Cooling Fan Replacement: 22 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 22 단계, 이미지 2개 중 2개
    • The old fan can be removed by sliding it out of the fan/heat sink assembly.
    • Note: You can use canned air to clean out the fan vents for better CPU cooling.
    • Insert the new fan into the fan slot in the fan/heat sink assembly. Put the assembly back together with the micro screws.
    • Before reassembly, make sure your new fan freely rotates within its housing.
    • CAUTION: Do not over-tighten the screws!
    The raw edit for "Before reassembly, make sure your new fan freely rotates within its housing." is necessary to avoid going through all of the steps again. I had to use a screwdriver as a wedge to widen the fan's housing distance from the fan, and blow into it to verify free fan rotation.
    Zen Balancer - 답글
  23. HP Pavilion dv7-6c90us Cooling Fan Replacement: 23 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 23 단계, 이미지 2개 중 2개
    • Use cotton swabs, paper towels, and alcohol to gently remove old thermal compound from the fan/heat sink assembly and motherboard.
    • CAUTION: Do not pour rubbing alcohol on the motherboard or other components! The rubbing alcohol may cause severe damage to your computer.
    • Apply a small amount of new thermal compound to the center of the brass section of the heat sink. Both areas that need new thermal compound are marked with red boxes.
    • CAUTION: Use the thermal compound manufacturer’s recommended amount. Applying too much or too little of it may damage your computer.
  24. HP Pavilion dv7-6c90us Cooling Fan Replacement: 24 단계, 이미지 2개 중 1개 HP Pavilion dv7-6c90us Cooling Fan Replacement: 24 단계, 이미지 2개 중 2개
    • Re-attach the heat sink assembly to the motherboard.
    • CAUTION: Do not over-tighten screws. Finger tighten them until snug. If you apply too much torque, you may damage components.
    • Using light pressure, shift the fan/heat sink gently back and forth to spread the thermal compound. This makes a solid connection between the heat sink and motherboard.
    Nice manual. I always use this one when I am laying hand my notebook. I would just say that it takes less time: I need around 3 h to disassemble, clean and reassemble.
    Robert Köllner - 답글
결론
Follow the steps in reverse order to reassemble.
Once you have reassembled the laptop, your repair is complete. If you need additional help, see the HP Pavilion dv7 Maintenance and Service Guide on HP's support website (link to guide: http://h10032.www1.hp.com/ctg/Manual/c03...).
다른 43명이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Angelina Clayton
회원 가입일: 06/24/15
250 평판
안내서 1개를 작성함
Colorado Springs, Team 1-1, Mcmichael SU 2015 Colorado Springs, Team 1-1, Mcmichael SU 2015 회원
UCCS-MCMICHAEL-SU15S1G1
3 회원들
안내서 1개 작성
15 Guide Comments
My HP Pavilion dv7 Cooling Fan failed and this procedure was exactly what I needed to install a new fan. The steps are right on. I would have done a lot of experimentation and possible damage had I not had this reference to follow. Thank you very much.
Wutever Canada - 답글
The link on the last page is incomplete and doesn't work
420 - 답글
You used way too much thermal compound.
A pea sized drop will be just fine, my dude.
Playstation3techsony - 답글
the link works just fine!by the way author i thank you for your work,its really help me!!
elconejolucho - 답글
Extremely helpful,thank you
Bryan Jones - 답글
Today is August 31,2017
Thank you so much! I just did this today following your directions, with my husbands help. It took us a little less than 3 hrs. All is well, actually great! My HP dv7 is up and running great! Thanks again. I'm sure without this guide I would have goofed up somewhere.
beckerelves - 답글
Extremely helpful, thank you so much.
I did have a bit of a hiccup. When pulling the heat sync assembly off the motherboard the thermal compound let go suddenly. The assembly ended up hitting a capacitor and popping it off the motherboard. I managed to do some very tiny soldering and put the capacitor back on the board (seems to have worked).
For my edification and others’, is there a better way to pry the heat sync assembly off the board? Some sort of tool to put beneath it somehow and gently pry it loose (without somehow damaging the CPU or GPU?
Jeff Slutz - 답글
Thank you for the time and effort putting this step-by-step guide together. It was extremely valuable in helping me restore my laptop to original performance. Job well done!
Dennis Zlatkin - 답글
Thanks! done in 1 hour!
Stefan Kruidenier - 답글
This guide was invaluable, my fan was jamming and I had tried an external exhaust fan with little luck. I needed to keep my computer running to support legacy software. I managed to complete the task following the steps.
Chris Wharton - 답글
To the author, one thing.
Your a God! , without you, I would’ve had a pile of junk leftover and a bunch of screws.
Thank you very much!
Diana Ocampo - 답글
Really useful guide - it made the job very doable. The DV7 I was fixing also had a biometric fingerprint reader to disconnect and re connect that was hard to get to.
I did a time lapse video of re assembly for some fun…
http://www.colin-west.com/for-friends/di...
cpwest - 답글
This instruction was a gift!
It was very accurate in most places and enabled me to successfully replace my dv7 fan in about 6 hours. I never would have even attempted it without this detailed procedure. I imagine a computer shop would have charged hundreds of dollars for this repair. I gained enough confidence that I would attempt other repairs on my own now.
There were a couple of issues: There were several connectors still holding the motherboard in place that were not addressed. One was the backup battery, two other connectors on the bottom, one near the card reader and a second small display connector near the fan - easily handled though.
The only real problem I encountered was removing the top cover. It made popping sounds as I pried it up all right. Turned out some of the pops were locking catches and the right-rear threaded insert breaking off. Still it went back together ok and worked perfectly when I turned it back on.
Thank you!
rcw3586 - 답글
First part to fail. Hardest part to access. Would have been nuts to pay someone to do this repair. Thank you for this!!
peggy - 답글
Your steps and instructions were perfect and provided the guide I needed to replace the CPU fan. I agree with the other commenter that there were a few additional plug connections that had to be disconnected but they were very obvious and easy to do. I actually drew the picture of the bottom of the notebook with the screw locations on a folded-over large piece of cardboard. Each screw I would sink (punch) into its location in the picture. It worked great. Thank you so much for your time and effort to help us all! We owe you.
Wayne Bellamy - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 47
전체 시간: 42,549
