주요 콘텐츠로 건너뛰기
HP Pavilion x360 11m-ad013dx Battery Replacement
필요한 것
  1. HP Pavilion x360 11m-ad013dx Battery Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Lay the HP Pavilion top-down with the front edge facing towards you.
  2. HP Pavilion x360 11m-ad013dx Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the three 4.8mm Phillips #0 screws from the front side.
  3. HP Pavilion x360 11m-ad013dx Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 11m-ad013dx Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Using a plastic spudger, remove the grey silicon strip closest to the back-side.
  4. HP Pavilion x360 11m-ad013dx Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Remove the three 5.7mm Phillips #1 screws.
  5. HP Pavilion x360 11m-ad013dx Battery Replacement: 5 단계, 이미지 2개 중 1개 HP Pavilion x360 11m-ad013dx Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Open the HP Pavilion so that the screen is showing. Then tilt it down so that the screen is on its back, facing up.
    • Using a spudger, pry off the black keyboard panel.
    • This step requires force to unclasp the latches keeping the keyboard in place.
  6. HP Pavilion x360 11m-ad013dx Battery Replacement: 6 단계, 이미지 2개 중 1개 HP Pavilion x360 11m-ad013dx Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Using your fingernail, disconnect the zero insertion force (ZIF) keyboard connector cable by flipping up the small locking flap.
    • You may disconnect the other end of the cable, for ease of access to other parts. Keep in mind that the end labeled MB connects to the motherboard.
  7. HP Pavilion x360 11m-ad013dx Battery Replacement: 7 단계, 이미지 2개 중 1개 HP Pavilion x360 11m-ad013dx Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Using your fingernail, disconnect the zero insertion force (ZIF) connector for the touch pad cable by flipping up the small locking flap.
  8. HP Pavilion x360 11m-ad013dx Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the keyboard.
  9. HP Pavilion x360 11m-ad013dx Battery Replacement, Battery: 9 단계, 이미지 1개 중 1개
    • Remove the five 4.6mm Phillips #1 screws located around the battery.
  10. HP Pavilion x360 11m-ad013dx Battery Replacement: 10 단계, 이미지 2개 중 1개 HP Pavilion x360 11m-ad013dx Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Using a spudger for assistance, lift up the right edge of the battery.
    • Remove the battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Hank Ferguson
회원 가입일: 01/13/20
590 평판
안내서 4개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 34
전체 시간: 1,565
