주요 콘텐츠로 건너뛰기
HP Pavilion x360 14-ba253cl Battery Replacement
필요한 것
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: 1 단계, 이미지 1/1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: 2 단계, 이미지 1/1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: 3 단계, 이미지 1/1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: 4 단계, 이미지 1/1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: 5 단계, 이미지 1/1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: 6 단계, 이미지 1/1
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: 7 단계, 이미지 1/1
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
ryan reichard
회원 가입일: 10/15/19
270 평판
안내서 1개 작성함
댓글 한 개
Thanks, it was useful
Oleg - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 28
30일 전: 97
전체 시간: 8,417
