주요 콘텐츠로 건너뛰기
HP Pavilion x360 14-ba253cl Battery Replacement
필요한 것
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: 1 단계, 이미지 1개 중 1개
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: 5 단계, 이미지 1개 중 1개
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: 6 단계, 이미지 1개 중 1개
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: 7 단계, 이미지 1개 중 1개
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
ryan reichard
회원 가입일: 10/15/19
270 평판
안내서 1개를 작성함
1가이드 댓글
Thanks, it was useful
Oleg - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 82
전체 시간: 10,367
