주요 콘텐츠로 건너뛰기
HP Pavilion x360 14m-ba011dx RAM Replacement
필요한 것
  1. HP Pavilion x360 14m-ba011dx RAM Replacement, Battery: 1 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx RAM Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the top left and right rubber pads closest to the hinge of screen using a plastic spudger to expose the screws underneath.
    • Remove the following 6 screws from the bottom of the device using a Phillips #00 Screwdriver:​
    • Two 7.5 mm screws.
    • Three 5 mm screws.
    • One 6.5 mm screw.
  2. HP Pavilion x360 14m-ba011dx RAM Replacement: 2 단계, 이미지 1개 중 1개
    • Push into the two screw holes that were under the rubber pads with the screwdriver to pop the keyboard out just a little.
    • Do this with the screen open so that you do not damage the screen.
    • Do not remove keyboard all the way.
  3. HP Pavilion x360 14m-ba011dx RAM Replacement: 3 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Separate the keyboard from the rest of the device using a metal or plastic spudger around the edges.
    • Pull up gently just until you can see the cables attaching the keyboard to the motherboard.
    • Flip the small white flaps holding the cables to the motherboard open to unplug the cords.
  4. HP Pavilion x360 14m-ba011dx RAM Replacement: 4 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx RAM Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the purple cable attaching the battery to the motherboard by flipping the black flap and pulling the cable out.
    • Remove seven 4 mm screws using a Phillips #00 Screwdriver.
  5. HP Pavilion x360 14m-ba011dx RAM Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the battery by gently pushing battery up, then pulling.
  6. HP Pavilion x360 14m-ba011dx RAM Replacement, Motherboard: 6 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx RAM Replacement, Motherboard: 6 단계, 이미지 2개 중 2개
    • Unclip the 5 cables connecting the motherboard to the computer.
  7. HP Pavilion x360 14m-ba011dx RAM Replacement: 7 단계, 이미지 1개 중 1개
    • Remove ten 4 mm screws using a Phillips #00 screwdriver.
  8. HP Pavilion x360 14m-ba011dx RAM Replacement: 8 단계, 이미지 1개 중 1개
    • Gently remove the motherboard.
  9. HP Pavilion x360 14m-ba011dx RAM Replacement, RAM: 9 단계, 이미지 2개 중 1개 HP Pavilion x360 14m-ba011dx RAM Replacement, RAM: 9 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip the motherboard upside down and remove the silver box covering the RAM sticks.
    • Using your fingers or a pair of tweezers, pull the edges of the card to the side and lift the RAM out of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Katie Pruis
회원 가입일: 01/16/20
820 평판
안내서 5개를 작성함
1 Guide Comment
Don't forget the WIFI chip in step 7, take out the silver screw first before taking off the motherboard.
Jerri - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 36
전체 시간: 3,467
