주요 콘텐츠로 건너뛰기
HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement
필요한 것
  1. 주의: 1-3 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Prerequisites: 1 단계, 이미지 1개 중 1개
    • Power down the device.
    • Flip the device face side down so the back of the device is facing up.
  2. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Disassembly: 2 단계, 이미지 3개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Disassembly: 2 단계, 이미지 3개 중 2개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Disassembly: 2 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove the two 4.5 mm screws securing the battery cover located at the bottom center of the device.
    • Remove the cover.
  3. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Replacement: 3 단계, 이미지 3개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Replacement: 3 단계, 이미지 3개 중 2개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery.
  4. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Button Panel: 4 단계, 이미지 2개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Button Panel: 4 단계, 이미지 2개 중 2개
    • Using a Phillips #00 screwdriver, remove the four 4.5 mm screws securing the back panel to the device.
  5. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 5 단계, 이미지 3개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 5 단계, 이미지 3개 중 2개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 5 단계, 이미지 3개 중 3개
    • Using a spudger, gently pry apart the front and back panels.
  6. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 6 단계, 이미지 3개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 6 단계, 이미지 3개 중 2개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 6 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using a Phillips #00 screwdriver, remove the eleven 3 mm screws securing the battery board/button panel located at the bottom half of the device.
    • Using a plastic opening tool, gently pry the retaining clip securing the ribbon cable to the top-left side of the board.
    • Using plastic tweezers, gently unplug the ribbon cable from the board.
  7. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 7 단계, 이미지 3개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 7 단계, 이미지 3개 중 2개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 7 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, gently pry upward on the battery board/button panel from the bottom to remove.
  8. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Motherboard/Display: 8 단계, 이미지 2개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement, Motherboard/Display: 8 단계, 이미지 2개 중 2개
    • Remove the lower component from the motherboard
  9. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 9 단계, 이미지 3개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 9 단계, 이미지 3개 중 2개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 9 단계, 이미지 3개 중 3개
    • Using a Phillips #00 screwdriver, remove the four screws securing the motherboard/display to the front panel.
    • Using a plastic opening tool, pry up the locking tab of the ZIF connector on the right side of the device and pull out the ribbon cable.
    • Using a plastic opening tool, gently pry apart the motherboard and the front panel.
  10. HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 10 단계, 이미지 2개 중 1개 HP Prime Graphing Calculator G8X92A Motherboard/Display Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the motherboard from the display.
결론
다른 2명이 해당 안내서를 완성하였습니다.
3가이드 댓글
Hi Eric,
Do you know where we could buy / get a screen replacement? I looked everywhere, but I cannot find it.
Led Hilderink - 답글
Hi, did you find it?
Alcides Cruz -
Also looking for a replacement and cannot find any sellers anywhere!
James - 답글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 21
지난 30일: 84
전체 시간: 3,931
