주요 콘텐츠로 건너뛰기
HP ProBook 5330m Battery Replacement
필요한 것
  1. HP ProBook 5330m Battery Replacement, Battery Cover: 1 단계, 이미지 1/3 HP ProBook 5330m Battery Replacement, Battery Cover: 1 단계, 이미지 2/3 HP ProBook 5330m Battery Replacement, Battery Cover: 1 단계, 이미지 3/3
    • The battery cover is locked in place by a switch on the bottom of the laptop.
    • To release the lock and open the battery cover, slide the switch in the direction of the arrow next to the battery icon.
    • As you slide the switch, the battery cover should pop up.
  2. HP ProBook 5330m Battery Replacement: 2 단계, 이미지 1/1
    • Lift up and remove the battery cover.
  3. HP ProBook 5330m Battery Replacement, Battery: 3 단계, 이미지 1/1
    • Two switches lock the battery in place. To remove the battery you will need to slide both switches toward the center of the battery.
    • The switch marked with a padlock symbol moves back and forth freely.
    • The switch with the battery symbol on the other side of the battery is spring loaded, so you will have to hold it open as you remove the battery.
  4. HP ProBook 5330m Battery Replacement: 4 단계, 이미지 1/2 HP ProBook 5330m Battery Replacement: 4 단계, 이미지 2/2
    • Slide the switch with the padlock symbol toward the unlocked side.
  5. HP ProBook 5330m Battery Replacement: 5 단계, 이미지 1/2 HP ProBook 5330m Battery Replacement: 5 단계, 이미지 2/2
    • Insert your finger or the flat edge of a spudger into the small divot along the edge of the battery just below the battery cover lock.
    • Slide the spring-loaded switch with the battery symbol toward the center of the battery with one hand, while you pry the battery up with the other.
    • If you have correctly released both of the switches that hold the battery in place, it should be very easy to pry up.
    • Don't pry aggressively at the battery. If you can't hold the switch open while you pry, have a friend hold the switch while you lift out the battery.
  6. HP ProBook 5330m Battery Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
  7. HP ProBook 5330m Battery Replacement: 7 단계, 이미지 1/3 HP ProBook 5330m Battery Replacement: 7 단계, 이미지 2/3 HP ProBook 5330m Battery Replacement: 7 단계, 이미지 3/3
    • To install your new battery, press it into place so that it lays flat, then slide the red switch with the padlock symbol back to the locked side.
결론
For optimal performance, calibrate your newly-installed battery: Charge it to 100% and keep charging it for at least 2 more hours. Then use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
Repair didn’t go as planned? Check out our HP ProBook answers community for troubleshooting help.
Taylor Dixon
회원 가입일: 06/26/18
67,829 평판
안내서 94개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 14
전체 시간: 1,261
