주요 콘텐츠로 건너뛰기
HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement
필요한 것
  1. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Bottom Cover: 1 단계, 이미지 1/2 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Bottom Cover: 1 단계, 이미지 2/2
    • Turn off and unplug the laptop.
    • Flip over the laptop so that the bottom backplate is exposed.
  2. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 2 단계, 이미지 1/2 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 2 단계, 이미지 2/2
    • Use a T5 screwdriver to remove the six 3 mm screws that secure the backplate.
    • Use the same screwdriver to remove the two 7 mm screws.
  3. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 3 단계, 이미지 1/3 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 3 단계, 이미지 2/3 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 3 단계, 이미지 3/3
    • Insert an opening tool under the bottom cover at the screen hinges, and gently pry the cover free.
    • Carefully work your way around the cover's edges to pop it off completely.
  4. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Heatsink and Fan Assembly: 4 단계, 이미지 1/3 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Heatsink and Fan Assembly: 4 단계, 이미지 2/3 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement, Heatsink and Fan Assembly: 4 단계, 이미지 3/3
    • Use a Phillips #0 Screwdriver to remove the four circled 3 mm screws.
    • Use the same screwdriver to remove the circled 4 mm screw.
  5. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 5 단계, 이미지 1/2 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 5 단계, 이미지 2/2
    • Remove black adhesive tape and metal shielding.
  6. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 6 단계, 이미지 1/2 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 6 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to remove the last 4 mm screw under the black tape.
    • Unplug the cable next to the fan.
  7. HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 7 단계, 이미지 1/2 HP Spectre x360 13t-4000 Heatsink and Fan Assembly Replacement: 7 단계, 이미지 2/2
    • Remove heatsink and fan assembly.
    • Reapply fresh thermal paste to the CPU before placing a heatsink back in the device.
결론
Justin Dages
회원 가입일: 03/28/23
361 평판
안내서 3개 작성하였습니다
IUPUI, Team 2-5, Harley Spring 2023 IUPUI, Team 2-5, Harley Spring 2023 회원
IUPUI-HARLEY-S23S2G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 15
전체 시간: 145
