주요 콘텐츠로 건너뛰기
HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement
필요한 것
  1. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Unscrew the back cover: 1 단계, 이미지 1/1
    • Be sure to completely power off and unplug your laptop before you begin your repair. Make sure the laptop is not in standby, sleep, or hibernation mode.
    • Use a T5 driver to remove the following screws securing the back cover:
    • Six 4 mm-long screws
    • Two 7.8 mm-long screws
  2. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Loosen the back cover: 2 단계, 이미지 1/2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Loosen the back cover: 2 단계, 이미지 2/2
    • Use an opening tool or your fingers to pry up the back cover from the laptop.
    • Plastic clips hold the back cover lightly in place, so you may encounter some resistance.
    • If it feels like there is strong resistance, you may have a model that includes screws under the corner feet. Carefully pry the feet up to make sure they don't have screws.
  3. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the back cover: 3 단계, 이미지 1/2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the back cover: 3 단계, 이미지 2/2
    • Lift and remove the back cover.
    • During reassembly, gently press along the perimeter of the back cover to re-engage the clips.
  4. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Disconnect the battery: 4 단계, 이미지 1/3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Disconnect the battery: 4 단계, 이미지 2/3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Disconnect the battery: 4 단계, 이미지 3/3
    • Pry the edges of the battery connector with a spudger to loosen the connector from its motherboard socket.
    • Gently pull the connector parallel to the motherboard to disconnect it.
  5. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the Wi-Fi card: 5 단계, 이미지 1/2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement, Remove the Wi-Fi card: 5 단계, 이미지 2/2
    • Use your fingers or tweezers to peel the black plastic strip until you uncover the Wi-Fi card.
  6. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: 6 단계, 이미지 1/3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: 6 단계, 이미지 2/3 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: 6 단계, 이미지 3/3
    • Use the point of a spudger to carefully pry up and disconnect the two antenna cables from the Wi-Fi card.
  7. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: 7 단계, 이미지 1/1
    • Use a Phillips screwdriver to remove the 2.8 mm-long screw securing the Wi-Fi card to the motherboard.
  8. HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: 8 단계, 이미지 1/2 HP Spectre x360 15" (15t-ap000) Wi-Fi Card Replacement: 8 단계, 이미지 2/2
    • Grasp the Wi-Fi card edges with your fingers and pull it at a shallow angle parallel to the motherboard.
    • Remove the Wi-Fi card.
결론
Arthur Shi
회원 가입일: 01/03/18
253,419 평판
안내서 526개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 17,198개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 57
전체 시간: 1,590
