주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HP Stream 11-y010nr Battery Replacement
필요한 것
  1. HP Stream 11-y010nr Battery Replacement, Keyboard: 1 단계, 이미지 3개 중 1개 HP Stream 11-y010nr Battery Replacement, Keyboard: 1 단계, 이미지 3개 중 2개 HP Stream 11-y010nr Battery Replacement, Keyboard: 1 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Battery Replacement: 2 단계, 이미지 2개 중 1개 HP Stream 11-y010nr Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Battery Replacement: 3 단계, 이미지 2개 중 1개 HP Stream 11-y010nr Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Battery Replacement: 5 단계, 이미지 3개 중 1개 HP Stream 11-y010nr Battery Replacement: 5 단계, 이미지 3개 중 2개 HP Stream 11-y010nr Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Battery Replacement, Battery: 6 단계, 이미지 3개 중 1개 HP Stream 11-y010nr Battery Replacement, Battery: 6 단계, 이미지 3개 중 2개 HP Stream 11-y010nr Battery Replacement, Battery: 6 단계, 이미지 3개 중 3개
    • Use your fingers or a spudger to pull the battery cable out from its connector.
  7. HP Stream 11-y010nr Battery Replacement: 7 단계, 이미지 2개 중 1개 HP Stream 11-y010nr Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Unscrew the six 0.4mm screws surrounding the battery with a Phillips #1 screwdriver.
  8. HP Stream 11-y010nr Battery Replacement: 8 단계, 이미지 3개 중 1개 HP Stream 11-y010nr Battery Replacement: 8 단계, 이미지 3개 중 2개 HP Stream 11-y010nr Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully lift up on the battery.
    • If the black and white wire on the bottom is intertwined with the bracket, gently pull the wire off the battery.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 16
지난 30일: 87
전체 시간: 4,734
