주요 콘텐츠로 건너뛰기
HP Stream 11-y010nr Trackpad Replacement
필요한 것
  1. HP Stream 11-y010nr Trackpad Replacement, Keyboard: 1 단계, 이미지 1/3 HP Stream 11-y010nr Trackpad Replacement, Keyboard: 1 단계, 이미지 2/3 HP Stream 11-y010nr Trackpad Replacement, Keyboard: 1 단계, 이미지 3/3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Trackpad Replacement: 2 단계, 이미지 1/2 HP Stream 11-y010nr Trackpad Replacement: 2 단계, 이미지 2/2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Trackpad Replacement: 3 단계, 이미지 1/2 HP Stream 11-y010nr Trackpad Replacement: 3 단계, 이미지 2/2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Trackpad Replacement: 4 단계, 이미지 1/1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Trackpad Replacement: 5 단계, 이미지 1/3 HP Stream 11-y010nr Trackpad Replacement: 5 단계, 이미지 2/3 HP Stream 11-y010nr Trackpad Replacement: 5 단계, 이미지 3/3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Trackpad Replacement, Trackpad: 6 단계, 이미지 1/2 HP Stream 11-y010nr Trackpad Replacement, Trackpad: 6 단계, 이미지 2/2
    • Take the keyboard and flip it over. It will look like the pictures.
    • Use the needle nose tweezer to take off protective tape covering the top left and top right screws.
  7. HP Stream 11-y010nr Trackpad Replacement: 7 단계, 이미지 1/3 HP Stream 11-y010nr Trackpad Replacement: 7 단계, 이미지 2/3 HP Stream 11-y010nr Trackpad Replacement: 7 단계, 이미지 3/3
    • Unscrew the three 0.2mm top screws with the Phillips #00 Screwdriver.
  8. HP Stream 11-y010nr Trackpad Replacement: 8 단계, 이미지 1/3 HP Stream 11-y010nr Trackpad Replacement: 8 단계, 이미지 2/3 HP Stream 11-y010nr Trackpad Replacement: 8 단계, 이미지 3/3
    • Unscrew the three 0.3mm screws holding the bottom bracket with the Phillips #00 Screwdriver.
  9. HP Stream 11-y010nr Trackpad Replacement: 9 단계, 이미지 1/3 HP Stream 11-y010nr Trackpad Replacement: 9 단계, 이미지 2/3 HP Stream 11-y010nr Trackpad Replacement: 9 단계, 이미지 3/3
    • Lift up on the bracket and remove the bracket by lifting up on the metal end as shown.
  10. HP Stream 11-y010nr Trackpad Replacement: 10 단계, 이미지 1/3 HP Stream 11-y010nr Trackpad Replacement: 10 단계, 이미지 2/3 HP Stream 11-y010nr Trackpad Replacement: 10 단계, 이미지 3/3
    • The trackpad is now free to be removed.
    • Remove the trackpad by gently pulling up on the metal piece on the bottom left corner of the trackpad.
결론
To reassemble your device, follow these instructions.
다른 한 분이 해당 안내서를 완성하였습니다.
Adam Sitzmann
회원 가입일: 01/26/20
914 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 12
전체 시간: 260
