주요 콘텐츠로 건너뛰기
HP Stream 11-y010nr WiFi Card Replacement
필요한 것
  1. HP Stream 11-y010nr WiFi Card Replacement, Keyboard: 1 단계, 이미지 1/3 HP Stream 11-y010nr WiFi Card Replacement, Keyboard: 1 단계, 이미지 2/3 HP Stream 11-y010nr WiFi Card Replacement, Keyboard: 1 단계, 이미지 3/3
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr WiFi Card Replacement: 2 단계, 이미지 1/2 HP Stream 11-y010nr WiFi Card Replacement: 2 단계, 이미지 2/2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr WiFi Card Replacement: 3 단계, 이미지 1/2 HP Stream 11-y010nr WiFi Card Replacement: 3 단계, 이미지 2/2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr WiFi Card Replacement: 4 단계, 이미지 1/1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr WiFi Card Replacement: 5 단계, 이미지 1/3 HP Stream 11-y010nr WiFi Card Replacement: 5 단계, 이미지 2/3 HP Stream 11-y010nr WiFi Card Replacement: 5 단계, 이미지 3/3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr WiFi Card Replacement, WiFi Card: 6 단계, 이미지 1/3 HP Stream 11-y010nr WiFi Card Replacement, WiFi Card: 6 단계, 이미지 2/3 HP Stream 11-y010nr WiFi Card Replacement, WiFi Card: 6 단계, 이미지 3/3
    • Use your fingers or a spudger to pull the battery cable out from its connector.
  7. HP Stream 11-y010nr WiFi Card Replacement: 7 단계, 이미지 1/2 HP Stream 11-y010nr WiFi Card Replacement: 7 단계, 이미지 2/2
    • Gently pry up the two coaxial cables from the WiFi card with the needle nose tweezers.
  8. HP Stream 11-y010nr WiFi Card Replacement: 8 단계, 이미지 1/2 HP Stream 11-y010nr WiFi Card Replacement: 8 단계, 이미지 2/2
    • Unscrew the 0.3mm screw on the WiFi card with the Phillips #1 screwdriver.
  9. HP Stream 11-y010nr WiFi Card Replacement: 9 단계, 이미지 1/2 HP Stream 11-y010nr WiFi Card Replacement: 9 단계, 이미지 2/2
    • Gently pull the WiFi card out leftwards.
결론
To reassemble your device, follow these instructions in reverse order. Make sure that you put the wires on the Wifi card to the correct location. Each of the cables are numbered with the wifi card having the numbers next to each plug.
Adam Sitzmann
회원 가입일: 01/26/20
914 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 9
30일 전: 20
전체 시간: 647
