주요 콘텐츠로 건너뛰기
HP Stream 8 Battery Replacement
필요한 것
  1. HP Stream 8 Battery Replacement, Midframe: 1 단계, 이미지 1/1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Battery Replacement: 2 단계, 이미지 1/1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Battery Replacement: 3 단계, 이미지 1/1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Battery Replacement: 4 단계, 이미지 1/1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Battery Replacement, Front-Facing Camera: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Battery Replacement: 6 단계, 이미지 1/1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Battery Replacement, Rear-Facing Camera: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Battery Replacement: 8 단계, 이미지 1/1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Battery Replacement, Motherboard: 9 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Battery Replacement: 10 단계, 이미지 1/1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Battery Replacement: 11 단계, 이미지 1/1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Battery Replacement: 12 단계, 이미지 1/1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Battery Replacement: 13 단계, 이미지 1/1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Battery Replacement: 14 단계, 이미지 1/1
    • Remove the motherboard from the device.
  15. HP Stream 8 Battery Replacement, Battery: 15 단계, 이미지 1/1
    • Remove the 6 PH00 Phillips screws.
  16. HP Stream 8 Battery Replacement: 16 단계, 이미지 1/1
    • The battery can now be removed from the device.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Nick Miller
회원 가입일: 04/11/16
669 평판
안내서 6개 작성하였습니다
Cal Poly, Team 34-14, Maness Spring 2016 Cal Poly, Team 34-14, Maness Spring 2016 회원
CPSU-MANESS-S16S34G14
4 회원들
안내서 12개 작성하였습니다
댓글 2개
We're I can buy battery for stream 8 tablet 4000mah
Marlon Ultado - 답글
Bonjour,
pouvez-vous m'indiquer où je pourrais trouver une batterie compatible ?
Bien cordialement
GAVALDA - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 29
전체 시간: 4,801
