주요 콘텐츠로 건너뛰기
HP Z2 Mini G3 CPU Fan Replacement
  1. HP Z2 Mini G3 CPU Fan Replacement, Access Panel: 1 단계, 이미지 1개 중 1개
    • Turn the device so the back-side of the device is facing you.
    • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
    • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
  2. HP Z2 Mini G3 CPU Fan Replacement: 2 단계, 이미지 2개 중 1개 HP Z2 Mini G3 CPU Fan Replacement: 2 단계, 이미지 2개 중 2개
    • Slide and hold the latch in the direction of the engraved arrow (to the right).
  3. HP Z2 Mini G3 CPU Fan Replacement: 3 단계, 이미지 2개 중 1개 HP Z2 Mini G3 CPU Fan Replacement: 3 단계, 이미지 2개 중 2개
    • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
  4. HP Z2 Mini G3 CPU Fan Replacement, CPU Fan: 4 단계, 이미지 1개 중 1개
    • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
  5. HP Z2 Mini G3 CPU Fan Replacement: 5 단계, 이미지 1개 중 1개
    • Swing the fan upward, to a 90-degree angle.
  6. HP Z2 Mini G3 CPU Fan Replacement: 6 단계, 이미지 2개 중 1개 HP Z2 Mini G3 CPU Fan Replacement: 6 단계, 이미지 2개 중 2개
    • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
  7. HP Z2 Mini G3 CPU Fan Replacement: 7 단계, 이미지 1개 중 1개
    • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
  8. HP Z2 Mini G3 CPU Fan Replacement: 8 단계, 이미지 1개 중 1개
    • Swing the fan up again and pull it out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 41
전체 시간: 1,919
