주요 콘텐츠로 건너뛰기
HP ZBook 15 Hard Drive Replacement
필요한 것
  1. HP ZBook 15 Hard Drive Replacement, Battery: 1 단계, 이미지 1/2 HP ZBook 15 Hard Drive Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Hard Drive Replacement, Back Cover: 2 단계, 이미지 1/1
    • Slide the right lever firmly to the right.
    • Slide the cover towards yourself to remove it.
  3. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: 3 단계, 이미지 1/1
    • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
    • The screws will remain inside the springs of the hard drive caddy cover.
  4. HP ZBook 15 Hard Drive Replacement: 4 단계, 이미지 1/2 HP ZBook 15 Hard Drive Replacement: 4 단계, 이미지 2/2
    • Pull the green tab away from the metal casing and lift the drive out.
  5. HP ZBook 15 Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
결론
다른 13명이 해당 안내서를 완성하였습니다.
Grant Terris
회원 가입일: 01/30/15
2,834 평판
안내서 12개 작성하였습니다
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G43
4 회원들
안내서 15개 작성하였습니다
댓글 3개
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - 답글
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - 답글
how hard disk i can buy for my zbook 15?
thanks
francesco perego - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 27
30일 전: 102
전체 시간: 29,270
