주요 콘텐츠로 건너뛰기
HP ZBook 15 Screen Replacement
필요한 것
  1. HP ZBook 15 Screen Replacement, Battery: 1 단계, 이미지 1/2 HP ZBook 15 Screen Replacement, Battery: 1 단계, 이미지 2/2
    • Flip the laptop over.
    • Slide the lever with the battery symbol beside it firmly until the battery pops out.
    • Remove the battery from the laptop.
  2. HP ZBook 15 Screen Replacement, Screen: 2 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Orient the laptop keyboard-side up.
    • Use tweezers to remove the adhesive covers for the screws.
  3. HP ZBook 15 Screen Replacement: 3 단계, 이미지 1/1
    • Remove the two 6mm screws with a Phillips #0 screwdriver.
  4. HP ZBook 15 Screen Replacement: 4 단계, 이미지 1/2 HP ZBook 15 Screen Replacement: 4 단계, 이미지 2/2
    • Pull the bezel away from the screen.
    • Be sure to go one edge at a time! Do not pull hard on the corners as it may crack the bezel.
  5. HP ZBook 15 Screen Replacement: 5 단계, 이미지 1/1
    • Remove the four 3mm screws with a Phillips #0 screwdriver near the corners of the screen to remove the display.
    • Be careful not to confuse any screws. They are close together and you may remove the back cover instead of the display.
  6. HP ZBook 15 Screen Replacement: 6 단계, 이미지 1/2 HP ZBook 15 Screen Replacement: 6 단계, 이미지 2/2
    • Do not peel the tape from the side closest to the bottom of the screen panel! This may rip out the connector's wires.
    • Gently lower the screen and lay it face down on the keyboard.
    • Lift the corners of the tape closest to the top of the screen and peel toward the center carefully.
    • Slowly pull the tape away from the sides.
    • Lift the tape and disconnect the screen connector.
    • You can leave the tape stuck to the cable connector and still be able to remove it.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Grant Terris
회원 가입일: 01/30/15
2,834 평판
안내서 12개 작성하였습니다
Cal Poly, Team 8-43, Amido Winter 2015 Cal Poly, Team 8-43, Amido Winter 2015 회원
CPSU-AMIDO-W15S8G43
4 회원들
안내서 15개 작성하였습니다
댓글 3개
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
dwakefield - 답글
My ZBook 15u g5 does not have any adhesive covers around the screen. How do I replace?
H B - 답글
Hello can i replace my hd screen with another fhd one?
Mohand Almohands - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 21
30일 전: 58
전체 시간: 16,545
