주요 콘텐츠로 건너뛰기
HP x2 10-p010wm Speaker Replacement
필요한 것
  1. HP x2 10-p010wm Speaker Replacement, Battery: 1 단계, 이미지 1/1
    • Pull the screen away from the keyboard.
  2. HP x2 10-p010wm Speaker Replacement: 2 단계, 이미지 1/2 HP x2 10-p010wm Speaker Replacement: 2 단계, 이미지 2/2
    • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
  3. HP x2 10-p010wm Speaker Replacement: 3 단계, 이미지 1/1
    • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
    • Do not pull up too hard; slowly slide it towards the screen.
  4. HP x2 10-p010wm Speaker Replacement: 4 단계, 이미지 1/1
    • Remove the eight 4mm Phillips #00 screws from the metal plate.
  5. HP x2 10-p010wm Speaker Replacement: 5 단계, 이미지 1/3 HP x2 10-p010wm Speaker Replacement: 5 단계, 이미지 2/3 HP x2 10-p010wm Speaker Replacement: 5 단계, 이미지 3/3
    • Slowly peel up any tape securing the wire to the metal cover.
    • Remove the metal cover to access the battery.
  6. HP x2 10-p010wm Speaker Replacement: 6 단계, 이미지 1/1
    • Remove the 4mm screw on the side.
  7. HP x2 10-p010wm Speaker Replacement: 7 단계, 이미지 1/1
    • Remove the black tape.
    • Pull the battery connector towards the battery to disconnect it from its socket.
  8. HP x2 10-p010wm Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the battery.
  9. HP x2 10-p010wm Speaker Replacement, Speaker: 9 단계, 이미지 1/2 HP x2 10-p010wm Speaker Replacement, Speaker: 9 단계, 이미지 2/2
    • Remove speakers on both sides.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Ojala
회원 가입일: 10/30/19
317 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S4-G3, Saloman Fall 2019 UMass Dartmouth, Team S4-G3, Saloman Fall 2019 회원
UMASSD-SALOMAN-F19S4G3
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 175
