주요 콘텐츠로 건너뛰기
HTC Desire 826 Headphone Jack Replacement
필요한 것
  1. HTC Desire 826 Headphone Jack Replacement, Battery: 1 단계, 이미지 1/3 HTC Desire 826 Headphone Jack Replacement, Battery: 1 단계, 이미지 2/3 HTC Desire 826 Headphone Jack Replacement, Battery: 1 단계, 이미지 3/3
    • Find a seam in the back of the device.
    • Insert the plastic spudger into the seam and pry off the back panel.
    • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
  2. HTC Desire 826 Headphone Jack Replacement: 2 단계, 이미지 1/3 HTC Desire 826 Headphone Jack Replacement: 2 단계, 이미지 2/3 HTC Desire 826 Headphone Jack Replacement: 2 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
    • Remove the metal bracket with the tweezers.
  3. HTC Desire 826 Headphone Jack Replacement: 3 단계, 이미지 1/1
    • Disconnect the battery cable from the motherboard with the tweezers.
  4. HTC Desire 826 Headphone Jack Replacement: 4 단계, 이미지 1/2 HTC Desire 826 Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Lift the battery with a plastic spudger and remove it from the device.
  5. HTC Desire 826 Headphone Jack Replacement, Headphone Jack: 5 단계, 이미지 1/3 HTC Desire 826 Headphone Jack Replacement, Headphone Jack: 5 단계, 이미지 2/3 HTC Desire 826 Headphone Jack Replacement, Headphone Jack: 5 단계, 이미지 3/3
    • Use the T5 screwdriver to remove the three 4.00 mm screws as shown.
    • Once the screws are removed, pry up the top plastic panel using the black nylon spudger.
  6. HTC Desire 826 Headphone Jack Replacement: 6 단계, 이미지 1/2 HTC Desire 826 Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Unscrew the two 4.00 mm screws attaching the bottom plastic panel using a T5 screwdriver.
    • Using the spudger, remove the bottom plastic piece.
  7. HTC Desire 826 Headphone Jack Replacement: 7 단계, 이미지 1/3 HTC Desire 826 Headphone Jack Replacement: 7 단계, 이미지 2/3 HTC Desire 826 Headphone Jack Replacement: 7 단계, 이미지 3/3
    이 단계에 사용된 도구:
    $3.99
    구매
    • Using the spudger, remove the bottom part of the motherboard.
    • Using the angled tweezers, disconnect the headphone jack from the motherboard.
    • Using the plastic spudger, pop out the circular silver piece and lift the top part of the motherboard.
  8. HTC Desire 826 Headphone Jack Replacement: 8 단계, 이미지 1/2 HTC Desire 826 Headphone Jack Replacement: 8 단계, 이미지 2/2
    • Using the angled tweezers, pop off the metal piece on top of the headphone jack.
    • Using the angled tweezers, remove the headphone jack.
결론
Payton Rawson
회원 가입일: 09/04/19
109 평판
안내서 1개 작성함
University of Alabama, Team S1-G2, Bedsole Fall 2019 University of Alabama, Team S1-G2, Bedsole Fall 2019 회원
UA-BEDSOLE-F19S1G2
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 8
전체 시간: 182
