소개
Use this guide to remove or replace your current MicroSD card.
부품
지정된 부품이 없습니다.
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
다른 7명이 해당 안내서를 완성하였습니다.
