주요 콘텐츠로 건너뛰기
HTC Evo 4G MicroSD card Replacement
필요한 것
  1. HTC Evo 4G MicroSD card Replacement, Rear Panel: 1 단계, 이미지 1/1
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. HTC Evo 4G MicroSD card Replacement: 2 단계, 이미지 1/1
    • Lift the rear panel off of the inner rear frame.
  3. HTC Evo 4G MicroSD card Replacement, Battery: 3 단계, 이미지 1/2 HTC Evo 4G MicroSD card Replacement, Battery: 3 단계, 이미지 2/2
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. HTC Evo 4G MicroSD card Replacement, MicroSD card: 4 단계, 이미지 1/1
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. HTC Evo 4G MicroSD card Replacement: 5 단계, 이미지 1/1
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Walter Galan
690,034 평판
안내서 1,203개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 10
전체 시간: 10,366
