주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
HTC One M9 Battery Replacement
필요한 것
  1. HTC One M9 Battery Replacement, MicroSD Card: 1 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement, MicroSD Card: 1 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement, MicroSD Card: 1 단계, 이미지 3개 중 3개
    • The microSD card tray is located on the upper right hand side of the phone, above the volume buttons. To open the tray, insert a microSD card eject tool, or a paperclip, into the small hole in the microSD card tray.
    • Then press the tool or paperclip to eject the microSD card tray.
    • This may require a significant amount of force.
    • When reinserting the microSD card, ensure that it is in the correct orientation to the tray. The electrical connectors should be inserted first, with the microSD card face up.
    • It is normal for the microSD to sit imperfectly in the tray. The microSD card is easy to reposition within the tray.
  2. HTC One M9 Battery Replacement, SIM Card: 2 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement, SIM Card: 2 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement, SIM Card: 2 단계, 이미지 3개 중 3개
    • Insert a SIM card eject tool or a paperclip into the small hole besides the SIM card tray, located on the upper section of the left edge of the phone.
    • Press to eject the tray.
    • When reinserting the SIM card, ensure that its contacts are facing to the rear side. The tapered corner of the SIM card has to point to the outer bottom corner of the tray.
  3. HTC One M9 Battery Replacement, Rear Case: 3 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement, Rear Case: 3 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement, Rear Case: 3 단계, 이미지 3개 중 3개
    • Using a plastic opening pick or a spudger, gently pry and remove the cover on top of the case.
    • Remove the two 4 mm T5 Torx screws on the top of the case.
  4. HTC One M9 Battery Replacement: 4 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement: 4 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement: 4 단계, 이미지 3개 중 3개
    • Work a plastic opening pick around the perimeter of the device to separate the rear case from the display assembly.
    • The SIM card tray and Micro SD card tray must be removed before the back cover can be removed.
    • Be careful around the power and volume buttons, as they are fairly delicate.
    • Be careful when separating the body from the display assembly, as the rear-facing camera may be stuck to the body with adhesive.
  5. HTC One M9 Battery Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use a pair of tweezers to get underneath the white and blue cable connectors and gently push them upwards to disconnect them.
  6. HTC One M9 Battery Replacement: 6 단계, 이미지 2개 중 1개 HTC One M9 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the two 1.5 mm screws that secure the battery connector to the motherboard, using a Phillips #00 screwdriver.
    • Use a spudger to gently pry up the battery connector from its socket.
    • Do not apply pressure to the socket.
  7. HTC One M9 Battery Replacement: 7 단계, 이미지 2개 중 1개 HTC One M9 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Peel back the Kapton tape from the ZIF connectors.
    • Use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and gently slide the cables out.
  8. HTC One M9 Battery Replacement: 8 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement: 8 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Using the tweezers, carefully lift the tape covering the electrical strip, as shown in the picture.
    • Be gentle when lifting the tape as it can tear easily.
    • Use a spudger or your fingernail to lift the hinged retainer clip on the ZIF connector, and slide the cable out.
  9. HTC One M9 Battery Replacement: 9 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement: 9 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Peel back the Kapton tape from the remaining three ZIF connectors, then use a spudger or your fingernail to lift the hinged retainer clips on the ZIF connectors, and slide the cables out from each.
    • The third ZIF connector is mostly underneath the motherboard. When reassembling your device, make sure it is placed back underneath.
  10. HTC One M9 Battery Replacement: 10 단계, 이미지 3개 중 1개 HTC One M9 Battery Replacement: 10 단계, 이미지 3개 중 2개 HTC One M9 Battery Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the dual LED flash cover with a pair of tweezers. The cover is held on with a small amount of adhesive.
    • Using a heated pair of tweezers would ease the removal of flash cover, as the heat helps weaken the adhesive .
    • Remove the cover using a minimum amount of force. The flash cover may be glued to the antenna cable(s) below.
    • Use a pair of tweezers to disconnect the two antenna cables near the camera.
    • Some models of this phone will have only one antenna cable at this location.
    • Disconnect the antenna cable near the bottom right of the phone.
  11. HTC One M9 Battery Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 4 mm T5 Torx screws that secure the motherboard.
  12. HTC One M9 Battery Replacement: 12 단계, 이미지 2개 중 1개 HTC One M9 Battery Replacement: 12 단계, 이미지 2개 중 2개
    • Use a pair of tweezers to lift the vibrator out of its slot.
    • Avoid damaging the wires connecting the vibrator to the motherboard. Use the minimum amount of force.
    • Use an iOpener or heat gun to loosen the adhesive at the bottom of the motherboard.
    • Refer to the iOpener Instructions for further info.
    • Use a plastic opening tool, or a spudger, along the edges of the case to gently pry the motherboard out of the case.
    • Gently lift the motherboard out of the case, beginning from the top corner (near the camera).
  13. HTC One M9 Battery Replacement, Battery: 13 단계, 이미지 2개 중 1개 HTC One M9 Battery Replacement, Battery: 13 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers, remove the tape from the bottom of the battery.
    • Use a spudger to carefully pry the battery up from the display assembly.
    • Take care not to puncture or bend the battery.
    • Take extreme care not to tear the power and volume buttons flex cable
결론
다른 42명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Michael Chan
회원 가입일: 04/14/15
2,336 평판
안내서 4개를 작성함
Cal Poly, Team 6-16, Maness Spring 2015 Cal Poly, Team 6-16, Maness Spring 2015 회원
CPSU-MANESS-S15S6G16
4 회원들
안내서 16개를 작성함
19가이드 댓글
I replaced the battery now but encountered a problem, as my phone wasn't working properly afterwards. When I switched on, it kind of reset to default and the play store app kept crashing, so I had to do a factory reset
Chris Felix - 답글
Removal went as directed, about to attempt in reverse! Wish me luck
jasonroll - 답글
Done all of this by the book but phone won't turn on charge screen lights up and charges but still won't turn on please help
cpopowski - 답글
You tore the power and volume button cable. It's a $10 replacement, no big deal. I did the same thing even after having repaired phones for years now.
Jonah -
For me works everything except touch screen :/ i dont know what i done wrong... screen works good, but can't touch it
Wojtoosh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 36
지난 30일: 215
전체 시간: 56,265
