주요 콘텐츠로 건너뛰기
HTC One Remix Motherboard Replacement
필요한 것
  1. HTC One Remix Motherboard Replacement, Motherboard: 1 단계, 이미지 1/1
    • Use the sim eject tool to remove the SIM cards on either side of the phone.
  2. HTC One Remix Motherboard Replacement: 2 단계, 이미지 1/1
    • Heat up the iOpener in the microwave for one minute. Place the iOpener on the top of the phone for three minutes.
    • iOpener Instructions
  3. HTC One Remix Motherboard Replacement: 3 단계, 이미지 1/1
    • Once the top of the phone is warm, use a plastic spudger to pry the top left corner up.
    • The top is glued on so it may be difficult to get off.
  4. HTC One Remix Motherboard Replacement: 4 단계, 이미지 1/1
    • Take out the small 3 mm screw that is on the top left side using a T5 bit.
  5. HTC One Remix Motherboard Replacement: 5 단계, 이미지 1/2 HTC One Remix Motherboard Replacement: 5 단계, 이미지 2/2
    • Use the plastic spudger to pry off the back cover. Place the tool in the SIM card insert and lift off the back cover with force. Continue to do this all around the phone.
    • Be careful to not break the wiring that is connected from the inside to the back of the phone.
    • The plastic spudger may not work. If this is the case, you may have to resort to using the metal prying tool. Please use with caution.
  6. HTC One Remix Motherboard Replacement: 6 단계, 이미지 1/2 HTC One Remix Motherboard Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • With tweezers, remove the small pieces of yellow tape that hold the phone in place.
    • Use the plastic prying tool to take off the three pieces of silver tape. They are located at the bottom right corner of the copper place.
    • Please note that the second photo is upside-down.
  7. HTC One Remix Motherboard Replacement: 7 단계, 이미지 1/3 HTC One Remix Motherboard Replacement: 7 단계, 이미지 2/3 HTC One Remix Motherboard Replacement: 7 단계, 이미지 3/3
    • With the plastic spudger, disconnect the eight ZIF connectors. Do this by lifting the small white lines up and pulling the ribbon from it.
    • Use tweezers to carefully detach the eight ribbon cables from the connectors.
  8. HTC One Remix Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the two 1 mm screws at the bottom right of the motherboard using a Phillips #00 screwdriver.
  9. HTC One Remix Motherboard Replacement: 9 단계, 이미지 1/2 HTC One Remix Motherboard Replacement: 9 단계, 이미지 2/2
    • Pull off one end of each of the five colored connecting cables from the motherboard.
    • Pull the black and red wire from the motherboard on the bottom left.
  10. HTC One Remix Motherboard Replacement: 10 단계, 이미지 1/1
    • Take out the four 3 mm screws that are on each corner of the motherboard using a Torx 4 screwdriver.
    • Gently lift the motherboard out of the phone using the plastic spudger.
    • Watch the ribbon connectors when removing the motherboard as they may get in the way.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marcos Loza
회원 가입일: 04/10/18
936 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 142
