주요 콘텐츠로 건너뛰기
HTC One Speaker Replacement
필요한 것
  1. HTC One Speaker Replacement, Speaker: 1 단계, 이미지 1/3 HTC One Speaker Replacement, Speaker: 1 단계, 이미지 2/3 HTC One Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: 2 단계, 이미지 1/1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: 3 단계, 이미지 1/1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: 4 단계, 이미지 1/1
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: 5 단계, 이미지 1/1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: 6 단계, 이미지 1/2 HTC One Speaker Replacement: 6 단계, 이미지 2/2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: 7 단계, 이미지 1/2 HTC One Speaker Replacement: 7 단계, 이미지 2/2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: 8 단계, 이미지 1/3 HTC One Speaker Replacement: 8 단계, 이미지 2/3 HTC One Speaker Replacement: 8 단계, 이미지 3/3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: 9 단계, 이미지 1/2 HTC One Speaker Replacement: 9 단계, 이미지 2/2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
결론
다른 16명이 해당 안내서를 완성하였습니다.
Alex
회원 가입일: 09/23/14
664 평판
안내서 1개 작성함
USF Tampa, Team 12-1, Blackwell Fall 2014 USF Tampa, Team 12-1, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S12G1
4 회원들
안내서 7개 작성하였습니다
2 댓글
Where to buy speaker???
bharatdshmkh - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 19,354
