주요 콘텐츠로 건너뛰기
HTC Radar 4G Battery Replacement
필요한 것
  1. HTC Radar 4G Battery Replacement, Slide off the back panel: 1 단계, 이미지 2개 중 1개 HTC Radar 4G Battery Replacement, Slide off the back panel: 1 단계, 이미지 2개 중 2개
    • Slide off the white back panel.
    • This is the time to remove the SIM card, so remove it now.
  2. HTC Radar 4G Battery Replacement, Remove the motherboard protector screws: 2 단계, 이미지 1개 중 1개
    • Remove the 4 silver T5 Torx screws from the motherboard protector.
    • Some screws may be stuck in. If so, use a pair of tweezers to carefully remove them from their holes.
  3. HTC Radar 4G Battery Replacement, Slide off the rear motherboard protector: 3 단계, 이미지 1개 중 1개
    • Carefully slide off the motherboard protector.
    • This may take some force if this is the first time opening the phone.
    • Take care not to apply too much downward force, because you may accidentally damage the sensitive components on the motherboard.
  4. HTC Radar 4G Battery Replacement, Remove the frame screws: 4 단계, 이미지 1개 중 1개
    • Remove the 2 black T5 Torx screws from the silver frame.
    • Make sure to not accidentally slip the screwdriver, because you may break sensitive components on the motherboard.
  5. HTC Radar 4G Battery Replacement, Remove the casing: 5 단계, 이미지 1개 중 1개
    • Gently push on the motherboard until the display starts to come out of its frame.
    • Once it is at about a 30-degree angle, grab the display and pull it downwards to remove it from the frame.
    • Remember, do this carefully. We don't want to end up with a dead motherboard.
  6. HTC Radar 4G Battery Replacement, Remove the battery: 6 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    iFixit Opening Picks (Set of 6)
    • Use a fingernail or an opening pick to lift the battery out of its slot.
    • Insert the opening pick on the right side at the top for best results.
    • Once it is at about a 30-degree angle, pull up on the battery to disconnect it.
결론
To reassemble your device, follow these instructions in reverse order. Calibrate your new battery for optimal performance.Take your e-waste to an R2 or e-Stewards certified recycler.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
hellonearth311
회원 가입일: 03/30/24
390 평판
안내서 3개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 12
전체 시간: 203
