주요 콘텐츠로 건너뛰기
HTC Vive Cosmos Motherboard Replacement
필요한 것
  1. HTC Vive Cosmos Motherboard Replacement, Remove the facerest: 1 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Remove the facerest: 1 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Remove the facerest: 1 단계, 이미지 3/3
    • Pull the bottom of the facerest straight away from the Vive Cosmos to unclip it from the Vive.
    • With the bottom unclipped, pull the top of the facerest away from the Vive to remove it.
  2. HTC Vive Cosmos Motherboard Replacement, Release the faceplate switch: 2 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Release the faceplate switch: 2 단계, 이미지 2/2
    • Use your finger to push the sliding faceplate release switch, sitting to the left of the lenses, toward the bottom of the Vive.
  3. HTC Vive Cosmos Motherboard Replacement, Remove the faceplate: 3 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Remove the faceplate: 3 단계, 이미지 2/2
    • While holding the switch in the bottom position, pull the faceplate straight up and away from the front of the Vive.
    • Remove the faceplate.
  4. HTC Vive Cosmos Motherboard Replacement, Unscrew the focus knob: 4 단계, 이미지 1/1
    • Use a T5 Torx driver to remove the 4.1 mm long screw securing the focus knob.
  5. HTC Vive Cosmos Motherboard Replacement, Remove the focus knob: 5 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Remove the focus knob: 5 단계, 이미지 2/2
    • Slide the focus knob out of the plastic housing, off of the focus rod, and remove it.
  6. HTC Vive Cosmos Motherboard Replacement, Unplug the audio connector: 6 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Unplug the audio connector: 6 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Unplug the audio connector: 6 단계, 이미지 3/3
    • Twist the 3.5 mm audio connector counter-clockwise slightly and slide its cable out from under the plastic retaining clip.
    • Lift the audio connector straight up to unplug it.
  7. HTC Vive Cosmos Motherboard Replacement, Unscrew the LCD and motherboard assembly: 7 단계, 이미지 1/1
    • Use a T5 Torx driver to remove the three 4.1 mm long screws securing the LCD and motherboard assembly.
  8. HTC Vive Cosmos Motherboard Replacement: 8 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement: 8 단계, 이미지 2/2
    • Gently peel up the stickers on either side of the front of the Vive. If possible, keep the stickers intact and reuse them.
  9. HTC Vive Cosmos Motherboard Replacement: 9 단계, 이미지 1/1
    • Use a T5 Torx driver to unscrew the screws securing the upper component cover and the LCD and motherboard assembly:
    • Sixteen 4.1 mm long screws
    • One captive screw
    • This screw is covered by a sticker. Poke your driver through the sticker to access the screw.
    • Two 4.1 mm long screws
    • These screws are covered by stickers. Poke your driver through the stickers to access the screws.
  10. HTC Vive Cosmos Motherboard Replacement, Remove the microphone: 10 단계, 이미지 1/1
    • Remove the microphone cover from the bottom edge of the headset.
  11. HTC Vive Cosmos Motherboard Replacement, Separate the microphone adhesive: 11 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Separate the microphone adhesive: 11 단계, 이미지 2/2
    • Slide an opening pick under the microphone to separate the adhesive securing it to the Vive.
    • If this is difficult, use a heated iOpener, hair dryer, or heat gun to apply heat to adhesive.
  12. HTC Vive Cosmos Motherboard Replacement, Remove the upper component cover: 12 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Remove the upper component cover: 12 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Remove the upper component cover: 12 단계, 이미지 3/3
    • Angle the bottom end of the upper component cover away from the front of the Vive.
    • Pull the upper component cover away from the front of the Vive and remove it.
  13. HTC Vive Cosmos Motherboard Replacement, Remove the camera connector covers: 13 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Remove the camera connector covers: 13 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Remove the camera connector covers: 13 단계, 이미지 3/3
    • Slide the camera connector covers on either side of the LCD and motherboard assembly away from the center off of the assembly and remove them.
  14. HTC Vive Cosmos Motherboard Replacement, Disconnect the cameras: 14 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Disconnect the cameras: 14 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Disconnect the cameras: 14 단계, 이미지 3/3
    • Peel the tape over the right camera connector back enough to access the camera's ZIF connector underneath.
    • Repeat the same process to peel back the tape over the left camera ZIF connector.
  15. HTC Vive Cosmos Motherboard Replacement: 15 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 15 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 15 단계, 이미지 3/3
    • Use the point of a spudger to flip up the small locking flap securing the right camera cable ZIF connector.
    • Carefully slide the camera connector cable straight out of its socket on the motherboard.
  16. HTC Vive Cosmos Motherboard Replacement: 16 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement: 16 단계, 이미지 2/2
    • Use the point of a spudger to flip up the small locking flap securing the left camera cable ZIF connector.
  17. HTC Vive Cosmos Motherboard Replacement, Disconnect the microphone: 17 단계, 이미지 1/1
    • Peel the yellow tape off of the microphone connector.
  18. HTC Vive Cosmos Motherboard Replacement: 18 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement: 18 단계, 이미지 2/2
    • Use the point of a spudger to flip up the small locking flap securing the microphone cable ZIF connector.
  19. HTC Vive Cosmos Motherboard Replacement: 19 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 19 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 19 단계, 이미지 3/3
    • Carefully slide the microphone connector cable straight out of its socket on the motherboard.
    • With the cable out of its socket, slide the cable toward the bottom of the Vive and out of its clip on the LCD and motherboard assembly.
    • Take care not to crease or tear the cable while you're moving it.
  20. HTC Vive Cosmos Motherboard Replacement, Remove the LCD and motherboard assembly: 20 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Remove the LCD and motherboard assembly: 20 단계, 이미지 2/2
    • Lift the LCD and motherboard assembly out of the headset.
    • The assembly is secured by clips around the edges. It may help to release the clips using a thin plastic tool, like an opening tool or a spudger.
  21. HTC Vive Cosmos Motherboard Replacement, Disconnect the LCD panels: 21 단계, 이미지 1/1
    • Use a T5 Torx driver to remove the four 2.9 mm long screws securing the LCD connectors.
  22. HTC Vive Cosmos Motherboard Replacement: 22 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 22 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 22 단계, 이미지 3/3
    • Use the flat end of a spudger to pry the LCD connectors straight up and out of their sockets on the daughterboard.
  23. HTC Vive Cosmos Motherboard Replacement, Remove the LCD frame assembly: 23 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Remove the LCD frame assembly: 23 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Remove the LCD frame assembly: 23 단계, 이미지 3/3
    • Gently pull the bottom edge of the midframe away from the bottom edges of the LCD frames to unclip the LCD frames from the midframe.
  24. HTC Vive Cosmos Motherboard Replacement: 24 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement: 24 단계, 이미지 2/2
    • Remove the LCD frame assembly from the midframe.
    • During reassembly, first seat the support rod in its slots in the midframe. Then gently press the rest of the LCD frame assembly into the midframe so that the bottom edges of the LCD frames clip into the midframe.
  25. HTC Vive Cosmos Motherboard Replacement, Disconnect the headset button: 25 단계, 이미지 1/1
    • Peel the yellow tape off of the headset button connector.
  26. HTC Vive Cosmos Motherboard Replacement: 26 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 26 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 26 단계, 이미지 3/3
    • Use the point of a spudger to flip up the small locking flap securing the headset button cable ZIF connector.
    • Carefully slide the headset button connector cable straight out of its socket on the motherboard.
  27. HTC Vive Cosmos Motherboard Replacement, Disconnect the fan cable: 27 단계, 이미지 1/1
    • Peel the black plastic sticker off of the left side of the motherboard.
  28. HTC Vive Cosmos Motherboard Replacement: 28 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 28 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 28 단계, 이미지 3/3
    • Use the tip of a spudger to push one side of the the fan connector slightly out of its socket on the motherboard, then push on the other side of the connector. Continue alternating pressure on each side to gently ease the connector out of its socket.
    • Apply pressure parallel to the motherboard. Do not pry up on the connector.
  29. HTC Vive Cosmos Motherboard Replacement, Disconnect the left camera: 29 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Disconnect the left camera: 29 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Disconnect the left camera: 29 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up the locking flap securing the left camera cable ZIF connector.
    • Carefully slide the camera cable straight out of its socket on the motherboard.
  30. HTC Vive Cosmos Motherboard Replacement, Disconnect the second interconnect cable: 30 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Disconnect the second interconnect cable: 30 단계, 이미지 2/2
    • Peel the yellow tape off of both the second interconnect cable and its socket on the motherboard.
  31. HTC Vive Cosmos Motherboard Replacement: 31 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 31 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 31 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up the locking flap securing the second interconnect cable ZIF connector.
    • Carefully slide the second interconnect cable straight out of its socket on the motherboard.
  32. HTC Vive Cosmos Motherboard Replacement, Disconnect the microphone: 32 단계, 이미지 1/1
  33. HTC Vive Cosmos Motherboard Replacement: 33 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 33 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 33 단계, 이미지 3/3
    • Carefully slide the microphone cable straight out of its socket.
  34. HTC Vive Cosmos Motherboard Replacement, Disconnect the right camera: 34 단계, 이미지 1/1
    • Peel the black plastic sticker off of the right side of the motherboard.
  35. HTC Vive Cosmos Motherboard Replacement: 35 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 35 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 35 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up the locking flap securing the right camera cable ZIF connector.
  36. HTC Vive Cosmos Motherboard Replacement, Unscrew the heat sink and motherboard: 36 단계, 이미지 1/1
    • Use a T5 Torx driver to remove the screws securing the motherboard, heat sink, and fan:
    • Five 4.1 mm long screws
    • One 8.5 mm long screw
  37. HTC Vive Cosmos Motherboard Replacement, Remove the heat sink bracket: 37 단계, 이미지 1/1
    • Remove the heat sink bracket.
  38. HTC Vive Cosmos Motherboard Replacement, Remove the heat sink: 38 단계, 이미지 1/2 HTC Vive Cosmos Motherboard Replacement, Remove the heat sink: 38 단계, 이미지 2/2
  39. HTC Vive Cosmos Motherboard Replacement: 39 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 39 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 39 단계, 이미지 3/3
    • Carefully thread the heatsink through its slot in the midframe and remove it.
  40. HTC Vive Cosmos Motherboard Replacement, Disconnect the motherboard: 40 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement, Disconnect the motherboard: 40 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement, Disconnect the motherboard: 40 단계, 이미지 3/3
    • Hinge the top end of the motherboard slightly away from the midframe.
    • Slide the motherboard up and out of the clips holding its bottom edge against the midframe.
    • Do not remove the motherboard yet, it is still connected to the daughterboard.
  41. HTC Vive Cosmos Motherboard Replacement: 41 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 41 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 41 단계, 이미지 3/3
    • Swing the motherboard toward the top of the midframe to access the underside of the motherboard.
    • A metal bracket with a screw boss and thermal paste will likely fall off of the motherboard during this step. Keep track of the bracket and during reassembly return it to its position, shown in the last photo. One of the motherboard screws will thread into it.
  42. HTC Vive Cosmos Motherboard Replacement: 42 단계, 이미지 1/1
    • Peel the tape over the daughterboard interconnect cable back far enough to access the cable connector.
  43. HTC Vive Cosmos Motherboard Replacement: 43 단계, 이미지 1/3 HTC Vive Cosmos Motherboard Replacement: 43 단계, 이미지 2/3 HTC Vive Cosmos Motherboard Replacement: 43 단계, 이미지 3/3
    • Use the flat end of a spudger to flip up the locking flap securing the interconnect cable ZIF connector.
    • Carefully slide the interconnect cable straight out of its socket.
    • Remove the motherboard.
  44. HTC Vive Cosmos Motherboard Replacement, Remove the motherboard: 44 단계, 이미지 1/1
    • Only the motherboard remains.
결론
Adam O'Camb
회원 가입일: 04/11/15
197,108 평판
안내서 416개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 17
전체 시간: 728
