주요 콘텐츠로 건너뛰기
HTC Vive XR Elite Headstraps Replacement
필요한 것
  1. HTC Vive XR Elite Headstraps Replacement, Prepare your Vive XR Elite for disassembly: 1 단계, 이미지 1개 중 1개
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Headstraps Replacement, Disconnect the USB-C power cable: 2 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Disconnect the USB-C power cable: 2 단계, 이미지 2개 중 2개
    • Disconnect the USB-C power cable.
  3. HTC Vive XR Elite Headstraps Replacement, Disconnect the battery cradle: 3 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Disconnect the battery cradle: 3 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Disconnect the battery cradle: 3 단계, 이미지 3개 중 3개
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
  4. HTC Vive XR Elite Headstraps Replacement: 4 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement: 4 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement: 4 단계, 이미지 3개 중 3개
    • Repeat the previous step for the left temple slot.
  5. HTC Vive XR Elite Headstraps Replacement, Separate the headset and battery cradle: 5 단계, 이미지 1개 중 1개
    • Separate the headset and battery cradle.
  6. HTC Vive XR Elite Headstraps Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Insert an opening pick: 6 단계, 이미지 2개 중 2개
    • Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
  7. HTC Vive XR Elite Headstraps Replacement, Release the top clips: 7 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Release the top clips: 7 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Release the top clips: 7 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge of battery cradle to release its plastic clips.
  8. HTC Vive XR Elite Headstraps Replacement: 8 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement: 8 단계, 이미지 2개 중 2개
    • Flip the battery cradle over.
    • Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
  9. HTC Vive XR Elite Headstraps Replacement, Release the bottom clips: 9 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Release the bottom clips: 9 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Release the bottom clips: 9 단계, 이미지 3개 중 3개
    • Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
  10. HTC Vive XR Elite Headstraps Replacement, Separate the battery cradle halves: 10 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Separate the battery cradle halves: 10 단계, 이미지 2개 중 2개
    • Pull apart the two halves of the battery cradle to completely separate them.
  11. HTC Vive XR Elite Headstraps Replacement, Peel back the graphite thermal tape: 11 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Peel back the graphite thermal tape: 11 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Peel back the graphite thermal tape: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to peel back the graphite thermal tape covering the inner plastic frame.
    • If the tape tears a little, don't worry! During reassembly, stick it back in its original place as if it were still one piece
  12. HTC Vive XR Elite Headstraps Replacement, Unfasten the inner plastic frame: 12 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unfasten the inner plastic frame: 12 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Use a T5 Torx screwdriver to remove the nine screws securing the inner plastic frame:
    • Five 11.8 mm-long screws
    • Three 5.6 mm-long screws
    • One 5.6 mm-long screw
    • This screw is covered by a piece of black plastic tape. Use tweezers to remove it before unscrewing.
  13. HTC Vive XR Elite Headstraps Replacement, Remove the inner plastic frame: 13 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the inner plastic frame: 13 단계, 이미지 2개 중 2개
    • Remove the inner plastic frame, making sure to thread the graphite thermal tape through it.
  14. HTC Vive XR Elite Headstraps Replacement, Unfasten the headstrap clips: 14 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unfasten the headstrap clips: 14 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the two 5.6 mm-long screws securing the headstrap clips.
  15. HTC Vive XR Elite Headstraps Replacement, Remove the headstrap clips: 15 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the headstrap clips: 15 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the headstrap clips: 15 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers to remove the left and right headstrap clips.
  16. HTC Vive XR Elite Headstraps Replacement, Peel back the battery board thermal pad: 16 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Peel back the battery board thermal pad: 16 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Peel back the battery board thermal pad: 16 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use tweezers or your fingers to peel back the thermal pad covering the battery board.
    • Work slowly to avoid tearing the thermal pad.
  17. HTC Vive XR Elite Headstraps Replacement, Disconnect the batteries: 17 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Disconnect the batteries: 17 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Disconnect the batteries: 17 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to push the left and right battery cell connectors out of their respective sockets.
  18. HTC Vive XR Elite Headstraps Replacement, Disconnect the power LED: 18 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Disconnect the power LED: 18 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Disconnect the power LED: 18 단계, 이미지 3개 중 3개
    • Use the point of a spudger to flip up the locking flap on the power LED ZIF connector.
    • Use tweezers or your fingers to disconnect the power LED cable.
    • During reassembly, slide the cable into the connector and close the locking flap. If the cable is getting stuck, gently remove it and realign it before trying again.
  19. HTC Vive XR Elite Headstraps Replacement, Disconnect the USB-C power cable: 19 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Disconnect the USB-C power cable: 19 단계, 이미지 2개 중 2개
    • Pull the black tab straight up on the USB-C power cable to disconnect it.
    • During reassembly, align the cable directly over the connector and press straight down to reconnect it.
  20. HTC Vive XR Elite Headstraps Replacement, Peel back the conductive tape: 20 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Peel back the conductive tape: 20 단계, 이미지 2개 중 2개
    • Use tweezers or your fingers to peel the conductive tape away from the front metal battery enclosure.
  21. HTC Vive XR Elite Headstraps Replacement, Unfasten the battery board: 21 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unfasten the battery board: 21 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the battery board.
  22. HTC Vive XR Elite Headstraps Replacement, Remove the battery board: 22 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the battery board: 22 단계, 이미지 2개 중 2개
    • Remove the battery board.
  23. HTC Vive XR Elite Headstraps Replacement, Unfasten the front metal battery cover: 23 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unfasten the front metal battery cover: 23 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the three screws securing the front metal battery enclosure:
    • Two 11.8 mm-long screws
    • One 4.8 mm-long screw
  24. HTC Vive XR Elite Headstraps Replacement, Unclip the USB-C power cable: 24 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unclip the USB-C power cable: 24 단계, 이미지 2개 중 2개
    • Slide the USB-C power cable to the left to unclip it.
  25. HTC Vive XR Elite Headstraps Replacement, Remove the front metal battery enclosure: 25 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the front metal battery enclosure: 25 단계, 이미지 2개 중 2개
    • Remove the front metal battery enclosure.
  26. HTC Vive XR Elite Headstraps Replacement, Reposition the battery cradle: 26 단계, 이미지 1개 중 1개
    • Stand the battery cradle upright so the battery cells can fold flat on your work surface.
  27. HTC Vive XR Elite Headstraps Replacement, Remove the right battery cell: 27 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the right battery cell: 27 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the right battery cell: 27 단계, 이미지 3개 중 3개
    • Don't try to fully remove the batteries yet, as they're still attached to the cradle with graphite thermal tape.
    • Peel off the graphite thermal tape covering the right battery cell.
    • Remove the right battery cell.
  28. HTC Vive XR Elite Headstraps Replacement, Remove the left battery cell: 28 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the left battery cell: 28 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the left battery cell: 28 단계, 이미지 3개 중 3개
    • Repeat the previous step for the left battery cell.
  29. HTC Vive XR Elite Headstraps Replacement, Remove the rear metal battery enclosure: 29 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the rear metal battery enclosure: 29 단계, 이미지 2개 중 2개
    • Grip the center plastic screw spacer with your fingers.
    • Remove the rear metal battery enclosure.
  30. HTC Vive XR Elite Headstraps Replacement, Remove the USB-C power cable: 30 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the USB-C power cable: 30 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the USB-C power cable: 30 단계, 이미지 3개 중 3개
    • Hold one end of the USB-C power cable and pull it straight back to unclip it.
    • Remove the USB-C power cable.
  31. HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial faceplate: 31 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial faceplate: 31 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial faceplate: 31 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Tesa 61395 Tape
    $2.99
    • Insert an opening pick under the adjustment dial faceplate.
    • Pry up to separate the adhesive securing the faceplate.
    • Remove the faceplate.
    • During reassembly, clean off any old adhesive using high-strength (>90%) isopropyl alcohol and a lint-free cloth. Use Tesa Tape to secure the faceplate to the adjustment dial.
  32. HTC Vive XR Elite Headstraps Replacement, Remove the plastic tape: 32 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the plastic tape: 32 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use tweezers to remove the plastic tape covering the adjustment dial screw.
  33. HTC Vive XR Elite Headstraps Replacement, Unfasten the adjustment dial: 33 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unfasten the adjustment dial: 33 단계, 이미지 2개 중 2개
    • Use a Torx T5 screwdriver to remove the 3.8 mm-long screw securing the adjustment dial.
  34. HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial screw spacer: 34 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial screw spacer: 34 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial screw spacer: 34 단계, 이미지 3개 중 3개
    • Insert an opening pick between the adjustment dial and the screw spacer.
    • Pry the screw spacer away from the adjustment dial to remove it.
  35. HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial: 35 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial: 35 단계, 이미지 2개 중 2개
    • Pull the adjustment dial straight off the cradle and remove it.
  36. HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial sprocket: 36 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial sprocket: 36 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the adjustment dial sprocket: 36 단계, 이미지 3개 중 3개
    • Use the point of a spudger to pry up the center of the sprocket.
    • Remove the adjustment dial sprocket.
  37. HTC Vive XR Elite Headstraps Replacement, Adjustment dial sprocket reassembly information: 37 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Adjustment dial sprocket reassembly information: 37 단계, 이미지 2개 중 2개
    • Adjust the headstraps so they're fully retracted into the cradle.
    • Insert the sprocket so its teeth fully mesh with the teeth in the socket.
  38. HTC Vive XR Elite Headstraps Replacement, Adjustment dial reassembly information: 38 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Adjustment dial reassembly information: 38 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Adjustment dial reassembly information: 38 단계, 이미지 3개 중 3개
    • During reassembly, make sure three pegs on the adjustment dial are inserted into the three cutouts on the sprocket:
    • Three adjustment dial pegs
    • Three sprocket cutouts
    • Use the molding marks to align the dial over the cutouts on the sprocket.
    • You'll know the dial is installed correctly when it easily turns counterclockwise and clicks when turned clockwise.
  39. HTC Vive XR Elite Headstraps Replacement, Unfasten the headstrap guide: 39 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Unfasten the headstrap guide: 39 단계, 이미지 2개 중 2개
    • Use a T5 Torx screwdriver to remove the four 4.1 mm-long screws securing the headstrap guide.
  40. HTC Vive XR Elite Headstraps Replacement, Remove the headstrap guide: 40 단계, 이미지 2개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the headstrap guide: 40 단계, 이미지 2개 중 2개
    • Remove the headstrap guide
    • The headstraps will spring up when the guide is removed.
  41. HTC Vive XR Elite Headstraps Replacement, Remove the headstraps: 41 단계, 이미지 3개 중 1개 HTC Vive XR Elite Headstraps Replacement, Remove the headstraps: 41 단계, 이미지 3개 중 2개 HTC Vive XR Elite Headstraps Replacement, Remove the headstraps: 41 단계, 이미지 3개 중 3개
    • Remove the left and right headstraps
    • During reassembly, reinstall the right headstrap first and the left one on top of it.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
작성자
2다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,820 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 12
전체 시간: 598
