주요 콘텐츠로 건너뛰기
HTC Vive XR Elite Rear Padding Replacement
필요한 것
  1. HTC Vive XR Elite Rear Padding Replacement, Prepare your Vive XR Elite for disassembly: 1 단계, 이미지 1개 중 1개
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
  2. HTC Vive XR Elite Rear Padding Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Insert an opening pick: 2 단계, 이미지 2개 중 2개
    • Insert a long edge of an opening pick in the gap between the two halves of the battery cradle, near the USB-C cable.
  3. HTC Vive XR Elite Rear Padding Replacement, Release the top clips: 3 단계, 이미지 3개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Release the top clips: 3 단계, 이미지 3개 중 2개 HTC Vive XR Elite Rear Padding Replacement, Release the top clips: 3 단계, 이미지 3개 중 3개
    • Slide the opening pick along the top edge of battery cradle to release its plastic clips.
  4. HTC Vive XR Elite Rear Padding Replacement: 4 단계, 이미지 2개 중 1개 HTC Vive XR Elite Rear Padding Replacement: 4 단계, 이미지 2개 중 2개
    • Flip the battery cradle over.
    • Insert the long edge of an opening pick in the gap between the two halves of the battery cradle.
  5. HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: 5 단계, 이미지 3개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: 5 단계, 이미지 3개 중 2개 HTC Vive XR Elite Rear Padding Replacement, Release the bottom clips: 5 단계, 이미지 3개 중 3개
    • Slide the opening pick along the bottom edge of battery cradle to release its plastic clips.
  6. HTC Vive XR Elite Rear Padding Replacement, Separate the battery cradle halves: 6 단계, 이미지 2개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Separate the battery cradle halves: 6 단계, 이미지 2개 중 2개
    • Pull apart the two halves of the battery cradle to completely separate them.
  7. HTC Vive XR Elite Rear Padding Replacement, Unfasten the rear padding: 7 단계, 이미지 2개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Unfasten the rear padding: 7 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    FixMat
    $31.41
    • Use a T5 Torx screwdriver to remove the four 4.9 mm-long screws securing the rear padding.
  8. HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: 8 단계, 이미지 3개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: 8 단계, 이미지 3개 중 2개 HTC Vive XR Elite Rear Padding Replacement, Unclip the rear padding: 8 단계, 이미지 3개 중 3개
    • Pivot one of the rear padding clips toward the center of the frame.
    • Lift the rear padding up to unclip it.
  9. HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: 9 단계, 이미지 3개 중 1개 HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: 9 단계, 이미지 3개 중 2개 HTC Vive XR Elite Rear Padding Replacement, Remove the rear padding: 9 단계, 이미지 3개 중 3개
    • The rear padding is not symmetrical. Note its orientation before continuing.
    • Unclip the remaining rear padding clip.
    • Remove the rear padding.
결론
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
작성자
1다른 기여자 명과 함께
Chayton Ritter
회원 가입일: 08/21/20
24,820 평판
안내서 105개를 작성함
Guide Team Guide Team 회원
Staff
10 회원들
안내서 15,763개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 6
전체 시간: 150
