주요 콘텐츠로 건너뛰기
Hannspree Hannspad SN1AT71 Battery Replacement
필요한 것
  1. Hannspree Hannspad SN1AT71 Battery Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Battery Replacement: 2 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Battery Replacement: 4 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Battery Replacement: 5 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Battery Replacement, Battery: 6 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Battery Replacement: 7 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement: 7 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Battery Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Battery Replacement: 8 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement: 8 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Battery Replacement: 8 단계, 이미지 3개 중 3개
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Battery Replacement: 9 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Battery Replacement: 9 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Battery Replacement: 9 단계, 이미지 3개 중 3개
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
결론
다른 9명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
matthew vandeventer
회원 가입일: 03/11/15
950 평판
안내서 5개를 작성함
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 회원
UCCS-PANKO-S15S9G4
3 회원들
안내서 10개를 작성함
댓글 3개
Easy to follow,but, can't find a battery anywhere, so really No use
Lawrence Pearce - 답글
Matthew,
Great job!!
I followed your instructions and no problem
Thanks
Me Eisenhut
Howard Eisenhut - 답글
Where can I buy a replacement battery?
mwause - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 28
전체 시간: 10,810
