주요 콘텐츠로 건너뛰기
Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement
필요한 것
  1. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Place the tablet screen side up.
    • Make sure the device is turned off to avoid damage.
  2. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 2 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 2 단계, 이미지 2개 중 2개
    • Use the metal spudger to press an opening between the screen and back cover.
    • The plastic tabs are located on each corner of the back cover.
    • Be careful, as the plastic tabs are delicate.
  3. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 3 단계, 이미지 1개 중 1개
    • Wedge the plastic opening tool between the screen and the back panel to prevent re-engagement
  4. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 4 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Slide the metal spudger around the casing to separate it from the inside of the tablet.
  5. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 5 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Flip the tablet over so the screen side is down after all the tabs are separated.
    • Remove the back panel by delicately lifting it straight up.
  6. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: 6 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Battery: 6 단계, 이미지 2개 중 2개
    • Remove the adhesive tape from the power connection cables.
  7. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 7 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 7 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 7 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Instructions for desoldering can be found on the iFixit website.
    • The soldering iron is hot. It can burn you and it can cause damage to the wires and motherboard.
    • Grab hold of the red wire using the tweezers.
    • Desolder the red wire connection from the motherboard using the tip of the soldering iron.
    • Move the wire connection away from the motherboard.
    • Do not let the red wire connection touch other wires or the motherboard.
  8. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 8 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 8 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 8 단계, 이미지 3개 중 3개
    • Desolder the black and yellow wire connection from the motherboard by following the previous step.
    • When moving the wire connections, do not let the red wire connection touch other wires or the motherboard.
  9. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 9 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 9 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Insert the flat end of the nylon spudger between the battery and the case.
    • The battery is connected to the tablet with an adhesive tape and will come free slowly.
    • Do not puncture or bend the battery while removing. If your battery is swollen, take appropriate precautions.
  10. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: 10 단계, 이미지 2개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement, Front and Rear Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Identify the ribbon connecter attached to the camera and where it connects to the circuit board.
    • The two cameras are connected with one ribbon cable.
    • Zero insertion force connector.
  11. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 11 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 11 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 11 단계, 이미지 3개 중 3개
    • Disconnect the sliding zero insertion force (ZIF). Use the plastic opening tool or a fingernail to slide the tab out, then pull the cable out.
  12. Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 12 단계, 이미지 3개 중 1개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 12 단계, 이미지 3개 중 2개 Hannspree Hannspad SN1AT71 Front and Rear Camera Replacement: 12 단계, 이미지 3개 중 3개
    • Pull the cameras out of their resting places in a straight upward motion.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
matthew vandeventer
회원 가입일: 03/11/15
950 평판
안내서 5개를 작성함
Colorado Springs, Team 9-4, Panko Spring 2015 Colorado Springs, Team 9-4, Panko Spring 2015 회원
UCCS-PANKO-S15S9G4
3 회원들
안내서 10개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 5
전체 시간: 623
