주요 콘텐츠로 건너뛰기
Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement
필요한 것
  1. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Find the location of the damaged speaker. The speaker can be located above the battery pack on the forearm.
    • Find the damaged wire. It must be replaced with a new one.
  2. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: 2 단계, 이미지 1/2 Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: 2 단계, 이미지 2/2
    • Desolder the damaged wire from the speaker and replace it with a new one.
    • It will be beneficial to use the wire stripping tool in order to do this.
  3. Hasbro Iron Man Infinity Nano Gauntlet Speaker Replacement: 3 단계, 이미지 1/1
    • Once the new wire is attached to the speaker, it must then be reattached to the circuit board.
    • Once the new wires are securely placed in the correct spot, the hand can be put back together.
결론
Tori Mariano
회원 가입일: 02/24/23
347 평판
안내서 1개 작성함
Marist, Team 1-3, Chaterdon Spring 2023 Marist, Team 1-3, Chaterdon Spring 2023 회원
MARS-CHATERDON-S23S1G3
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 63
