소개
Are your heel tips worn down or missing? Walking on metal tips, or uneven worn down rubber tips can be extremely frustrating. With extensive wear, heel tips will naturally deteriorate. It is recommended that they are replaced before the inner tip begins to protrude. This is also important because having an unstable heel can lead to balancing issues.
If you or someone you know have worn down or missing heel tips, you can use this guide to learn how to simply replace your old heel tips with new tips. Why pay a shoe repair shop to replace heel tips, when you can do it yourself and save time and money.
필요한 것
Wedge a dull picket knife or jimmy between the top of the heel tip to help loosen and separate the tip.
pincer pliers will also help to remove the metal part from the steel tube inside. Be careful not to pull the steel tube out. If the tip is quite worn down to the tube, you might need to drill out the heel pin
Place the pin end of the new tip into the heels opening.
If you find the following cases:
Heel Pin too thick: Grind down the pin carefully to make them fit
Heel Pin too thin: You can hammer the pin on an avil to slightly flatten it out so that they fit snugly and can be hammered in, or twist some copper wire together and insert with the heel tip to make it thicker so that you can hammer it in snugly -
다른 15명이 해당 안내서를 완성하였습니다.
댓글 2개
I have just added a comment to help with this
