주요 콘텐츠로 건너뛰기
Heyday Suitcase Turntable Needle Replacement
  1. Heyday Suitcase Turntable Needle Replacement, Needle: 1 단계, 이미지 2개 중 1개 Heyday Suitcase Turntable Needle Replacement, Needle: 1 단계, 이미지 2개 중 2개
    • Before you begin the repair, turn off the record player and unplug the power cord.
    • Remove cartridge lock by pushing inwards (towards the needle arm, while lightly squeezing the sides by hand. Then pull downwards and towards you to disengage the locking hook. This will unhook the lock between cartridge and base.
  2. Heyday Suitcase Turntable Needle Replacement: 2 단계, 이미지 1개 중 1개
    • Disconnect the wires from the cartridge.
결론
To reassemble your device, follow these instructions in reverse order. Replace the needle by clipping it back onto the cartridge and then reconnect the wires to the correct part of the cartridge.
작성자
6다른 기여자 명과 함께
Caroline D'Amato
회원 가입일: 10/26/22
565 평판
안내서 6개를 작성함
UMass Dartmouth, Team 2-1, Petersen Fall 2022 UMass Dartmouth, Team 2-1, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S2G1
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 47
전체 시간: 868
