주요 콘텐츠로 건너뛰기
Heyday True Wireless Earbuds 8204 Case Battery Replacement
필요한 것
  1. Heyday True Wireless Earbuds 8204 Case Battery Replacement, Case Battery: 1 단계, 이미지 1/1
    • Use a spudger or other prying tool to gently pry open the case, starting near the metal hinge on the rear of the case.
    • Avoid using a screwdriver or metal spudger for prying as internal components can be damaged in the process.
  2. Heyday True Wireless Earbuds 8204 Case Battery Replacement: 2 단계, 이미지 1/1
    • Pry the earbud charging station with a spudger and remove it.
  3. Heyday True Wireless Earbuds 8204 Case Battery Replacement: 3 단계, 이미지 1/1
    • Use a Torx screwdriver to remove the six screws on the silver bracket securing the motherboard.
  4. Heyday True Wireless Earbuds 8204 Case Battery Replacement: 4 단계, 이미지 1/1
    • Pull the silver ring from the base of the case to reveal the motherboard.
    • Lift up and remove the motherboard from the case.
  5. Heyday True Wireless Earbuds 8204 Case Battery Replacement: 5 단계, 이미지 1/1
    • Using your index finger and thumb, gently remove the battery that is attached to the back of the motherboard.
    • Desolder the two battery connections from the back of the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Ben Davignon
회원 가입일: 10/28/22
493 평판
안내서 3개 작성하였습니다
UMass Dartmouth, Team 1-3, Petersen Fall 2022 UMass Dartmouth, Team 1-3, Petersen Fall 2022 회원
UMASSD-PETERSEN-F22S1G3
6 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 9
전체 시간: 321
