주요 콘텐츠로 건너뛰기
Hipstreet Equinox 2 Motherboard Replacement
필요한 것
  1. Hipstreet Equinox 2 Motherboard Replacement, Rear Case: 1 단계, 이미지 1/1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Motherboard Replacement: 2 단계, 이미지 1/1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Motherboard Replacement, Motherboard: 3 단계, 이미지 1/1
    • Unsolder these wires from the motherboard, it is a good idea to label these wires as you remove them according to the picture to the left.
  4. Hipstreet Equinox 2 Motherboard Replacement: 4 단계, 이미지 1/1
    • Remove contact strips by lifting gently on the clip indicated in this picture, then pulling strip out of the clip.
  5. Hipstreet Equinox 2 Motherboard Replacement: 5 단계, 이미지 1/1
    • Remove the 3.5mm screws located at these locations shown on the picture by using the PH00 screwdriver.
  6. Hipstreet Equinox 2 Motherboard Replacement: 6 단계, 이미지 1/1
    • Gently lift the motherboard out of the tablet, make sure no wires are still caught or attached while you lift the motherboard.
결론
Brandon Snodgrass
회원 가입일: 01/29/15
410 평판
안내서 4개 작성하였습니다
Clemson, Team 15-8, Shirley Winter 2015 Clemson, Team 15-8, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S15G8
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 373
