주요 콘텐츠로 건너뛰기
Hipstreet Equinox 2 Speaker Replacement
필요한 것
  1. Hipstreet Equinox 2 Speaker Replacement, Rear Case: 1 단계, 이미지 1/1
    • Remove the two 3mm screws using a PH00 screwdriver.
  2. Hipstreet Equinox 2 Speaker Replacement: 2 단계, 이미지 1/1
    • Use the blue plastic opening tool to gently pry the back case off.
  3. Hipstreet Equinox 2 Speaker Replacement, Speaker: 3 단계, 이미지 1/1
    • Use a plastic opening tool to remove the speakers from the case.
    • Desolder the wires from the motherboard.
    • Be sure to note which wire, red or black, corresponds to which connection on the motherboard.
  4. Hipstreet Equinox 2 Speaker Replacement: 4 단계, 이미지 1/1
    • Solder the wires of the new speaker to the motherboard as shown in the image.
  5. Hipstreet Equinox 2 Speaker Replacement: 5 단계, 이미지 1/1
    • Glue the speakers flat against their respective sound output panels with the silver sides facing out/towards the interior of the tablet.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Joel Miller
회원 가입일: 01/29/15
119 평판
안내서 1개 작성함
Clemson, Team 15-8, Shirley Winter 2015 Clemson, Team 15-8, Shirley Winter 2015 회원
CLEM-SHIRLEY-W15S15G8
5 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 200
