주요 콘텐츠로 건너뛰기
Hipstreet Titan Plus Battery Replacement
필요한 것
  1. Hipstreet Titan Plus Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 Hipstreet Titan Plus Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Before beginning this process, make sure the device is powered off.
    • Use the plastic opening tools from iFixit to safely remove the screen from the back of the device.
    • Lift and remove screen to reveal the battery and circuit board as seen in the picture.
  2. Hipstreet Titan Plus Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Preparing to remove the speaker.
    • Use spudger to remove the speaker from the back casing of the device.
    • Note: Handle with care
  3. Hipstreet Titan Plus Battery Replacement: 3 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove the black strips as shown in the picture from the wires using the tweezers.
    • Be careful of handling, if not done correctly you will need to replace.
  4. Hipstreet Titan Plus Battery Replacement: 4 단계, 이미지 2개 중 1개 Hipstreet Titan Plus Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Carefully use the spatula and spudger from iFixit to remove the battery from the device.
    • Note: The different color wires needs to be reconnected onto the proper terminals on the circuit board
    • Note: here is a how to solder and desolder connections guide to properly do step 5. 연결부 납땜 및 납제거 방법
    • Dispose of the old battery properly.
  5. Hipstreet Titan Plus Battery Replacement: 5 단계, 이미지 2개 중 1개 Hipstreet Titan Plus Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Heat the soldering iron to operating temperature.
    • Use caution as to not harm yourself when using the hot soldering iron.
    • Locate the black and red wires on the top of the circuit board.
    • Note: Remember the placement of the red and black wires on the circuit board.
    • Using the soldering iron, apply heat to the shiny solder point on the circuit board (Circled on the picture).
    • Note: Be sure not to break the wire when pulling the wires off. Let the solder melt in order to remove the wire.
    • Be sure to perform this task for both the black and red wires.
    • Note: If the iron is not hot enough, you might encounter unsuccessful removal of the wires. In order to correct this, let the soldering iron heat up completely to try this step again.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Justin Machnik
회원 가입일: 10/30/15
194 평판
안내서 1개를 작성함
UMass Dartmouth, Team 1-1, Miles Fall 2015 UMass Dartmouth, Team 1-1, Miles Fall 2015 회원
UMASSD-MILES-F15S1G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 13
전체 시간: 1,152
