주요 콘텐츠로 건너뛰기
Hisense Chromebook C11 Hard Drive Replacement
필요한 것
  1. Hisense Chromebook C11 Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Remove the front two hub caps.
    • When finished, you should be able to remove the back cover.
  2. Hisense Chromebook C11 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Unscrew the screws with the Phillips #00 screwdriver.
  3. Hisense Chromebook C11 Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pry the perimeter of the case open with the plastic opening tool.
    • Remove the back panel.
  4. Hisense Chromebook C11 Hard Drive Replacement, Battery: 4 단계, 이미지 1/1
    • Be careful not to puncture the battery with the screwdriver or any sharp instrument.
    • Unscrew the screws with the Phillips #000 screwdriver.
  5. Hisense Chromebook C11 Hard Drive Replacement: 5 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use the tweezers to unplug the battery.
  6. Hisense Chromebook C11 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove the battery.
  7. Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/2 Hisense Chromebook C11 Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/2
    • Unscrew all of the screws that you can access on the hard drive.
    • If you cannot reach the screw beneath the black strip, move on to the next step.
  8. Hisense Chromebook C11 Hard Drive Replacement: 8 단계, 이미지 1/3 Hisense Chromebook C11 Hard Drive Replacement: 8 단계, 이미지 2/3 Hisense Chromebook C11 Hard Drive Replacement: 8 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Remove the black strip using the tweezers.
  9. Hisense Chromebook C11 Hard Drive Replacement: 9 단계, 이미지 1/1
    • Unscrew the screw beneath the black strip if you haven't done so already.
  10. Hisense Chromebook C11 Hard Drive Replacement: 10 단계, 이미지 1/2 Hisense Chromebook C11 Hard Drive Replacement: 10 단계, 이미지 2/2
    • Remove the ribbon with the tweezers.
  11. Hisense Chromebook C11 Hard Drive Replacement: 11 단계, 이미지 1/2 Hisense Chromebook C11 Hard Drive Replacement: 11 단계, 이미지 2/2
    • Using the tweezers, carefully remove the latches attaching the silver computer chip.
  12. Hisense Chromebook C11 Hard Drive Replacement: 12 단계, 이미지 1/2 Hisense Chromebook C11 Hard Drive Replacement: 12 단계, 이미지 2/2
    • Continue gently removing all remaining points of attachment.
  13. Hisense Chromebook C11 Hard Drive Replacement: 13 단계, 이미지 1/1
    • Carefully remove the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chelsea Charles
회원 가입일: 10/09/18
422 평판
안내서 2개 작성하였습니다
USF Tampa, Team S1-G3, Leahy Fall 2018 USF Tampa, Team S1-G3, Leahy Fall 2018 회원
USFT-LEAHY-F18S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 16
전체 시간: 1,150
